I don’t believe that is a app or theme issue.
Yes, I solved it, I had to change settings on plex server site.
Thank you very much Wahman and iBaa for your help!
One more quick thing. What theme works better? I am not sure but I believe I installed the first one and it acts pretty weird sometimes (when I select a movie from my online library it shows on the left bottom corner and I have to click Up to select and play it).
Well i wouldn’t say one is better then another. Its really everyones personal preference. My personal preference is CyberGhost’s currently. I will try to explain the differences:
iBaa is the default (most stable) Plexconnect non theme version
CyberGhost is a combination of all the listed themes using PIL
stoffez is a theme using PIL
Falco is a theme with pause screens using PHP
brotuser is a pretty stable theme using PIL
wahlmanj is a theme with full screen gradient using PHP
PHP is older then PIL
Everything is based off of iBaa’s github
Thank you again Wahlman,
I did a small donation right now for the help given.
And trying to install Cyberghost now.
