i set opensubtitles in agents
and yes it works. it shows subs.
but when i have multiple versions in same movies.
it works only in one version.
please help
Are you naming your versions like this?
/Movies
/Pulp Fiction (1994)
Pulp Fiction (1994) - 1080p.mkv
Pulp Fiction (1994) - SD.m4v
After playback starts
movie file names are different.
i did search and selected subtitles.
but it still says “none” .
When I have it named exactly like you, what seems to happen is no matter what version I pick it shows the same version in the subtitle search. But I do get a list of choices for at least one of them
I changed the naming to the proper format thinking that was the problem as you see below.
I tried both together and both separately and get no results at all for anything
Kill Bill Vol. 1 (2003) Kill Bill Vol. 1 (2003) - 1080p.mkv
Kill Bill Vol. 1 (2003) Kill Bill Vol. 1 (2003) - 2160p.mkv
It doesn’t make sense to me
I’m going to chalk this one up to some kind of bug they’ll have to look into
thank you. i really hope this to be solved.
