OpenVPN bulit in login?
OpenVPN have the great OpenVPN client access.
https://openvpn.net/index.php/access-server/docs/admin-guides/457-connect-to-openvpn-access-server-using-the-connect-client.html
I wonder if it's possible for you to build it in to plex?
It should be perfect that when you login / start plex, plex login automatic on the VPN that you want.
That would be cool… And it would bolster the security in Plex!
That would be cool... And it would bolster the security in Plex!
Yes exactly, I have found the solution for the Rasplex at Raspberry PI so it auto connect to the VPN on startup.
Now, I only want it for the Plex-app on iOS, android and PC/MAC =)
If your iPhone is jailbroken, you can download “auto VPN” on Cydia. This allows any app, to autoconnect to your configurated VPN.
I like to see this on PHT
