Optimized Versions on Synology DS1821+
Server Version#: 1.28.2.6151
Hi
When I try to create an optimized version of some files it just sits at 0% and never progresses. Also there is a que of files to be optimized in conversions that I cant remove?
Any help is appreciated
Mat
Plex Media Server Logs_2022-09-15_22-04-43.zip (7.2 MB)
For future reference: Please turn on DEBUG logging again (you turned it off) and recreate the problem before posting logs. The logs you provided are of minimal use.
I did find you are monitoring more folders than DSM 7 can monitor using the default table size. (a well organized Photos library is the most common cause of overflowing the table)
Sep 15, 2022 22:01:05.207 [0x7fcae1c29b00] WARN - [Req#bc] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Sep 15, 2022 22:01:15.691 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Arrested Development (2003) [Comedy]/Season 2/Extras - Season 2" (28: No space left on device)
Sep 15, 2022 22:01:15.697 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Arrested Development (2003) [Comedy]/Season 1" (28: No space left on device)
Sep 15, 2022 22:01:15.714 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Arrested Development (2003) [Comedy]/Season 1/Extras - Season 1" (28: No space left on device)
Sep 15, 2022 22:01:15.722 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Archer (2009) (2009) [Animation]" (28: No space left on device)
Sep 15, 2022 22:01:15.726 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Archer (2009) (2009) [Animation]/theme-music" (28: No space left on device)
Sep 15, 2022 22:01:15.728 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Archer (2009) (2009) [Animation]/Season 9" (28: No space left on device)
Sep 15, 2022 22:01:15.732 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Archer (2009) (2009) [Animation]/Season 8" (28: No space left on device)
Sep 15, 2022 22:01:15.736 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Archer (2009) (2009) [Animation]/Season 7" (28: No space left on device)
Sep 15, 2022 22:01:15.741 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Archer (2009) (2009) [Animation]/Season 6" (28: No space left on device)
Sep 15, 2022 22:01:15.745 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Archer (2009) (2009) [Animation]/Season 5" (28: No space left on device)
Sep 15, 2022 22:01:15.751 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Archer (2009) (2009) [Animation]/Season 4" (28: No space left on device)
Sep 15, 2022 22:01:15.756 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Archer (2009) (2009) [Animation]/Season 3" (28: No space left on device)
Sep 15, 2022 22:01:15.762 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Archer (2009) (2009) [Animation]/Season 2" (28: No space left on device)
Sep 15, 2022 22:01:15.767 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Archer (2009) (2009) [Animation]/Season 12" (28: No space left on device)
Sep 15, 2022 22:01:15.771 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Archer (2009) (2009) [Animation]/Season 11" (28: No space left on device)
Sep 15, 2022 22:01:15.775 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Archer (2009) (2009) [Animation]/Season 10" (28: No space left on device)
Sep 15, 2022 22:01:15.779 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Archer (2009) (2009) [Animation]/Season 1" (28: No space left on device)
Sep 15, 2022 22:01:15.783 [0x7fcadedc3b00] ERROR - [Notify] Failed to add watch for "/volume1/NAS2/TV Shows/Archer (2009) (2009) [Animation]/Season 13" (28: No space left on device)
This procedure will calculate how many folder slots you need and then configure the Synology to accommodate that size.
Please apply this first, Turn DEBUG logging back on, Restart DSM, and recreate what isn’t working.
Hi ChuckPa, many thanks for you fast reply and advice. I have turned on DEBUG logging and run the folder increase script you suggested.
I then tried to optimize a TV episiode and it started but stopped.
I have uploaded more logs if you could please have a look.
Thanks,
Plex Media Server Logs_2022-09-16_15-19-42.zip (7.5 MB)
Sorry after the optimize stopped and said waiting I uploaded the logs. It appears to have started again now…
You have a permissions problem for /volume1/TV Other.
PlexMediaServer can’t read (or write) it.
Sep 16, 2022 13:11:55.428 [0x7f68a15bbb00] ERROR - Couldn't check for the existence of file "/volume1/TV Other/.grab": boost::filesystem::status: Permission denied: "/volume1/TV Other/.grab"
Shows up here too:
Sep 16, 2022 13:14:15.021 [0x7f689ec45b00] ERROR - [Notify] Failed to add watch for "/volume1/TV Other" (13: Permission denied)
Sep 16, 2022 13:14:15.102 [0x7f689ec45b00] DEBUG - [Notify] Can't open root directory "/volume1/TV Other" (boost::filesystem::directory_iterator::construct: Permission denied: "/volume1/TV Other")
Sep 16, 2022 13:14:21.187 [0x7f689d21eb00] DEBUG - NetworkServiceBrowser: Parsing SSDP schema for http://192.168.77.75:49154/MediaRenderer/desc.xml
After seeing these errors, are you attempting to store Optimized versions in that shared folder ?
Thanks ChuckPa, appreciate you checking the logs for me. No there’s been no attempts to store optimized versions there.
Can you see any other issues in the logs? Did I manage to increase the monitoring fodlers correctly?
Thanks again.
There are no other errors showing in your logs.
Would it be possible for you to recreate the error and capture another set of logs?
Hi ChuckPa, thanks again for your help. I am unable to reproduce the error now after your advice.
Optimized versions are now working.
Cheers
