I see that there is a newish option “Maximum simultaneous CPU transcodes” but the minimum value is 1. I would like to have a minimum value of 0, so I can disable CPU transcoding entirely and only allow GPU transcoding. I do want to keep GPU transcoding enabled and not disable transcoding generally, but I never want it to fall back to the CPU.
Basically, if GPU transcoding fails for any reason, it’s “tough luck” and a client must either direct play or wait until I’ve restarted my server so that GPU transcoding starts working again.
Please consider giving us this option. Thank you.
