Order by name function in photo libraries
Dear Plex Developer,
since one of the last PMS Server versions, the order by name function in the photo libraries no longer works. Please fix that. This function is very important to me.
Best regards
PMS 1.8.2.4209 on WD MyCloud PR2100
Please fix this little mistake. These are certainly only a few program lines…
PMS 1.9.0.4252 on WD PR2100
+1
Please fix that… That problem begins to be old…
Nothing has happened!
Version 1.9.2.4285 on WD PR2100
HELLO, IS ANYONE HERE???
Just downloaded the newest version 1.9.4.4325, and still no ability to sort photos by filename. I have thousands of pictures organized in folders, and then rename the pictures so that they’re in the order I want them to display. Once I select the folder, there’s no option at all, unless I’m missing something, to sort. I would have thought this is a very basic feature.
Are there any plans to add this feature?
I have found a manual solution (for the web version, not for ios or other)… Change the end url
Fall&limit=&sort=photo.originallyAvailableAt%2Cphoto.titleSort%2Cphoto.id%3Adesc
to
Fall&limit=&sort=photo.titleSort%3Adesc
But Team Plex, please fix this problem.
It still does not work with the current server version 1.9.6.4401. This is very annoying and not understandable!
