A photo library cannot be sorted by title
In the log we see that sorting is done first at ‘photo.originallyAvailableAt’ and second at ‘photo.titleSort’
I wish there was a way to amend this. I want to use Plex to view comics, but it doesn’t sort very well. I have tried to rename them alphabetically, by numbers, I’ve tried to change the dates on the files using ACDSee - nothing works. It seems like such a small issue to be so problematic. I mean if the most basic viewing programs can sort alphabetically, and Plex doesn’t. It leaves a bit of a sour taste in my mouth as I am a Plex Pass user.
Did anybody ever get an official answer ? It looks like recently the sort within folders has gone belly up. Can’t figure out how its sorted but its definitely not by name and there is no where to select the sort order within a folder. Yes you can sort your folders by name but not the photos within a folder - STUPID and complete useless…good that I didn’t pay anything.
Hi There - Just tried an older version 1.3.2.3112 which works perfectly fine for photo sort in folders. I also tried 1.7.0.3840 but that didn’t work so I’m going to try 1.4.xxx, 1.5.xxx and 1.6.xx to see if which one of the later versions are working. But if somebody know please update this forum…
Latest server 1.11.0 and latest iOS 4.23 finally fixed my picture sorting issue, by not having sort by folder.
Go to Plex download and choose Plex Pass before downloading.
Without the ability to sort photos by filename/title within an album or folder, the Photos functionality is useless to me. Plex devs, it sure seems like this would be a simple feature to add (or fix, since it sounds like it used to work?). What’s the holdup?
There has never been an ability to manually sort a sub folder. Regardless I made a feature request report for subfolders to be sortable/filterable like the top level. I make no promises or ETA
