OS X - Have to restart PlexConnect on computer reboot
Hi Guys,
Running OS X 10.10.1 on Mac Mini Server (not using the actual server app, just mac mini server hardware)
Latest PlexConnect, Latest PMS
Every time my server reboots, I have to manually restart the PlexConnect service using the sudo restart.bash command.
I have installed PC as a launchdaemon, and this all used to work fine. I think Yosemite broke it....
On the ATV, unless I restart the daemon, nothing gets discovered except for Home Sharing. The home screen does not populate with the "internet connected" icons (for lack of a better term)
I have attached the PlexConnect.log, but that only shows from when I restarted the daemon. Where can I get a log going back further?
Any ideas as to what I can try?
Try this plist instead:
https://github.com/wahlmanj/PlexConnect/blob/master/update/OSX/PlexConnect.bash
I assume you have automatic login enabled on your Mac so it doesn't have a password to login @ boot?
https://kb.wisc.edu/helpdesk/page.php?id=39258
Try... sudo launchctl list | grep plexconnect
Do you get a PID or Errornumber? See Install-Guide-Mac, too.
Thanks, I will try your plist.
Yeah, I do have auto login enabled :)
I get this output:
-                     78                     com.plex.plexconnect.bash
And output after switching to the above plist
831                   0                     com.plex.plexconnect.bash
 - 78 points to the error.
Difference to wahlman's file: "sleep 1"
I haven't seen this behavior unless one used a hacintosh...
I played around with the bash plist for iOS devices maybe this would work for you also if the prior test bash I provided doesn't work (Note this relies on google) Hopefull @baa won't kill me for this ;)
https://github.com/wahlmanj/plexconnect-app/blob/master/PlexConnect.bash
*Note wget required prior to use:
http://coolestguidesontheplanet.com/install-and-configure-wget-on-os-x/
Do you think that it may be because :
A) Yosemite has broken it?
B ) I have PC stored on my second HDD and not the OS drive?
Thanks, I'm gonna try with your first plist above.
With this new plist that relies on Google, does that mean that if there's no internet connection, I won't be able to use PC?
You need a internet connection to use PlexConnect. I knew one user that borrowed his neighbors internet, started up PlexConnect then disconnected the internet and PlexConnect still worked since all the apps had loaded on their aTV. You need to load the storeFront (apps) at minimum on your aTV.
https://forums.plex.tv/topic/97591-no-internet-plexconnect-doesnt-work/
Same issue happening using wahlman’s plist as well :confused:
Exact same output using grep command too :
  •                 78                     com.plex.plexconnect.bash
You can try to add a lager "sleep" amount of time into the plist maybe you will have success then. Since its server I'm not sure if that is the issue or something else. You can search for a thread on OS X server that may help you.
https://forums.plex.tv/topic/71085-a-guide-to-how-i-got-plexconnect-running-on-os-x-server-107/
But it’s not running the actual server software. I’m just going overseas for a few weeks. I’ll try move PC back into the OS HDD and see if it makes a diff
I don't see how that would fix it. I did find another possible option here. I would mess with the delay (sleep) function by 10 or 20 seconds. I think its a timing error but without testing more time its hard to say for sure.
https://github.com/iBaa/PlexConnect/issues/250
