OWI2Plex to generate XMLTV EPG for Enigma2 Boxes with OpenWebIf plugin
I’ve released a new version (0.1v11-alpha) of OWI2Plex to generate XMLTV EPG files from Enigma2 Boxes running the OpenWebIf plugin.
Regards,
C
Thanks for your effort for the enigma2 community :wink:
Although I am not using your tool, it sounds like a great possibility to get a useful, free xml guide.
Hi thks for the tools,
Do you run this in the stb or linux machine? as stb have only python 2.7.
Many thanks
@a2issa, no problem. I run it in a separate linux box (the one running plex). But it doesn’t have to be Linux, it runs well on Windows 10 too. Might run on previous versions but I haven’t tried.
Decided specifically on Python3 as Python2 is no longer upgraded supported and library availability might be an issue in the future (see https://www.python.org/doc/sunset-python-2/)
Hope the tool works well for you.
