Please add an option for the shuffle setting to persist while playing music, much like it does in iTunes/iOS/Spotify! Especially in PlexAmp, it’s annoying to not be able to shuffle music unless I globally shuffle the artist. I usually like to have my music on shuffle so stuff doesn’t get repetitive, but I still like to be able to select specific songs to listen to! Similarly, in the Plex Media Player, when I select a new song shuffle turns off, so I have to remember to re-enable it every time I select a new song. I’m not sure if this is intended behavior, but I’m loving using Plex to stream my music from my home at work, and an option for this at least would make it so much better! Thanks!
2022 clean-up: Plexamp 3 and 4 support Add to Queue / Play Next options that won’t otherwise touch/modify the play queue (e.g. keep the shuffle going).
