could someone tell me please, if Plex is useable on an iPhone 11?
I got the error message: The server couldn´t be reachable.
Thanks in advance!
Thanks in advance!
The current version of Plex (2026.8.0) officially supports any devices that can run iOS 16 or later.
Your iPhone 11 should be able to run either iOS 18.7.8 or 26.4.1, so if you are on these versions it should work.
Might pay to provide a screen shot of the error and also some logs to help with diagnosis, also confirm if you are local to Plex server (same network) or if this is a remote connection.
Thank you @ozsmac Yeah… i could provide regarding a screenshsot. (i´m busy).
I´ll use it for home streaming. On the other hand, i use it normaly when i´m not at home another Network). Friends, parents and so on…
