Server Version#: 1.19.3.2764
Player Version#: 8.0.0.0
I have a problem opening photos from the timeline view. Previously I could “open” photos in “timeline” view by clicking, now this only works in the standard “library” view.
Attaching short logs snippets from both timeline and library “fetch/open”.
In the later “timeline” mode the app only registers click but does not perform any fetch.
Is this the intended function?
— library view - working open —
05-11 08:45:56.393 i: Creating PhotoViewerActivity. 05-11 08:45:56.404 i: Fetching [method:GET] https://192.168.0.40:32400/:/timeline?guid=local%3A%2F%2F367638&key=%2Flibrary%2Fmetadata%2F367638&playQueueItemID=19186&ratingKey=367638&state=paused&token=…VzpG&X-Plex-Client-Identifier=ee2921907c0eb8a2-com-plexapp-android&X-Plex-Token=…VzpG 05-11 08:45:56.404 i: [Boot] PhotoViewerActivity took 6ms to run create behaviours. 05-11 08:45:56.404 i: Fetching [method:GET] https://192.168.0.40:32400/library/metadata/367638?hubCount=10&includeGeolocation=1&includeRelated=1&includeRelatedCount=5&X-Plex-Token=…VzpG 05-11 08:45:56.404 i: Fetching [method:GET] https://192.168.0.40:32400/library/metadata/367638?hubCount=10&includeGeolocation=1&includeRelated=1&includeRelatedCount=5&X-Plex-Token=…VzpG 05-11 08:45:56.410 i: Resuming PhotoViewerActivity. 05-11 08:45:56.422 i: [Boot] FragmentWithBehavioursDelegate took 0ms to run create behaviours. 05-11 08:45:56.423 i: [Boot] FragmentWithBehavioursDelegate took 0ms to run create behaviours. 05-11 08:45:56.423 i: [Boot] FragmentWithBehavioursDelegate took 0ms to run create behaviours. 05-11 08:45:57.277 i: [UserAction] Navigate back. 05-11 08:45:57.326 i: Fetching [method:GET] https://192.168.0.40:32400/:/timeline?guid=local%3A%2F%2F367638&key=%2Flibrary%2Fmetadata%2F367638&playQueueItemID=19186&ratingKey=367638&state=stopped&token=…VzpG&X-Plex-Client-Identifier=ee2921907c0eb8a2-com-plexapp-android&X-Plex-Token=…VzpG 05-11 08:45:57.342 i: Resuming GenericContainerActivity. 05-11 08:46:01.960 i: [pms] /192.168.0.229:51750 - GET /logging
— timeline view - failing open —
05-11 08:44:35.086 i: [pms] /192.168.0.229:51727 - GET /logging 05-11 08:44:44.721 i: [UserAction] Click item 20200420_161023 (/library/metadata/297632). 05-11 08:44:47.138 i: [UserAction] Click item 20200420_191117 (/library/metadata/297635). 05-11 08:44:48.172 i: [UserAction] Click item 20200420_191232 (/library/metadata/297638). 05-11 08:44:49.089 i: [UserAction] Click item 20200420_191246 (/library/metadata/297639). 05-11 08:44:52.359 i: [UserAction] Click item 20200420_191202 (/library/metadata/297636). 05-11 08:44:53.611 i: [UserAction] Click item 20200420_161053 (/library/metadata/297633). 05-11 08:44:56.282 i: [pms] /192.168.0.229:51736 - GET /logging
