PHT/Andoird not saving Preferences via PrefsObject menu. IOS & Plex/web work fine.
I have had several users post on my channel's thread that they were not able to save their username and password via PHT or the Android app. I just tested this out and they are correct. I am not sure if this is a client issue or a server issue. I just installed the latest plexpass PMS, PHT, and Plex for Android. I was not able to set the username and password settings via the PrefsObject menu item
It works fine on IOS and Plex/Web. But not PHT or Android. Does anyone else have this issue? Or is it something i need to change in my code. I haven't had this issue until recently. So it has to be some kind of update that was pushed out for PMS or the client apps.
Update: Android works fine. I was mistaken. I closed the app and went back in and it now works. PHT, though, is still a no go.
Here are some logs to look at.
The first one (unsuccessful) is through PHT.
Apr 20, 2014 19:36:40:664 [13184] DEBUG - Request: [192.168.1.100:59161] GET /:/plugins/com.plexapp.plugins.crunchyroll/prefs/set?queue_type=1&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (4 live)
Apr 20, 2014 19:36:40:664 [13184] DEBUG -  * queue_type => 1
Apr 20, 2014 19:36:40:664 [13184] DEBUG -  * X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Apr 20, 2014 19:36:40:664 [13184] DEBUG - We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Apr 20, 2014 19:36:40:664 [13184] DEBUG - Came in with a super-token, authorization succeeded.
Apr 20, 2014 19:36:40:664 [13184] DEBUG - Request range: 0 to 0
Apr 20, 2014 19:36:40:664 [13184] DEBUG - Plug-in com.plexapp.plugins.crunchyroll has been used 40 times.
Apr 20, 2014 19:36:40:664 [13184] DEBUG - [com.plexapp.plugins.crunchyroll] Sending command over HTTP (GET): /:/plugins/com.plexapp.plugins.crunchyroll/prefs/set?queue_type=1
Apr 20, 2014 19:36:40:664 [13184] DEBUG - (Capabilities) Adding WebKit.
Apr 20, 2014 19:36:40:664 [13184] DEBUG - (Capabilties) Passing down capabilities of 'protocols=http-video,shoutcast,webkit;videoDecoders=h264{profile:high&resolution:1080&level:51};audioDecoders=mp3,aac,dts{bitrate:800000&channels:8},ac3{bitrate:800000&channels:8}' to plug-in.
Apr 20, 2014 19:36:40:664 [13184] DEBUG - HTTP requesting to: http://127.0.0.1:59139/:/plugins/com.plexapp.plugins.crunchyroll/prefs/set?queue_type=1
Apr 20, 2014 19:36:41:068 [13184] DEBUG - [com.plexapp.plugins.crunchyroll] HTTP reply status 200, with 0 bytes of content.
Apr 20, 2014 19:36:41:070 [13184] DEBUG - Request: [192.168.1.100:59164] GET /video/crunchyroll?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (4 live)
Apr 20, 2014 19:36:41:070 [13184] DEBUG -  * X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Apr 20, 2014 19:36:41:070 [13184] DEBUG - We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Apr 20, 2014 19:36:41:070 [13184] DEBUG - Came in with a super-token, authorization succeeded.
Apr 20, 2014 19:36:41:070 [13184] DEBUG - Request range: 0 to 0
Apr 20, 2014 19:36:41:070 [13184] DEBUG - Plug-in com.plexapp.plugins.crunchyroll has been used 41 times.
Apr 20, 2014 19:36:41:070 [13184] DEBUG - [com.plexapp.plugins.crunchyroll] Sending command over HTTP (GET): /video/crunchyroll
Apr 20, 2014 19:36:41:070 [13184] DEBUG - (Capabilities) Adding WebKit.
Apr 20, 2014 19:36:41:070 [13184] DEBUG - (Capabilties) Passing down capabilities of 'protocols=http-video,shoutcast,webkit;videoDecoders=h264{profile:high&resolution:1080&level:51};audioDecoders=mp3,aac,dts{bitrate:800000&channels:8},ac3{bitrate:800000&channels:8}' to plug-in.
Apr 20, 2014 19:36:41:071 [13184] DEBUG - HTTP requesting to: http://127.0.0.1:59139/video/crunchyroll
The second one (successful) is through the Android app.
Apr 20, 2014 19:42:16:725 [9008] DEBUG - Request: [192.168.1.242:56519] GET /:/plugins/com.plexapp.plugins.crunchyroll/prefs/set?password= (2 live)
Apr 20, 2014 19:42:16:725 [9008] DEBUG -  * password =>
Apr 20, 2014 19:42:16:725 [9008] DEBUG -  * queue_type => 1
Apr 20, 2014 19:42:16:725 [9008] DEBUG -  * username =>
Apr 20, 2014 19:42:16:725 [9008] DEBUG -  * X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Apr 20, 2014 19:42:16:725 [9008] DEBUG - We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Apr 20, 2014 19:42:16:725 [9008] DEBUG - Came in with a super-token, authorization succeeded.
Apr 20, 2014 19:42:16:725 [9008] DEBUG - Plug-in com.plexapp.plugins.crunchyroll has been used 44 times.
Apr 20, 2014 19:42:16:725 [9008] DEBUG - [com.plexapp.plugins.crunchyroll] Sending command over HTTP (GET): /:/plugins/com.plexapp.plugins.crunchyroll/prefs/set?password=&queue_type=1&username=
Apr 20, 2014 19:42:16:725 [9008] DEBUG - HTTP requesting to: http://127.0.0.1:59139/:/plugins/com.plexapp.plugins.crunchyroll/prefs/set?password=&queue_type=1&username=
Apr 20, 2014 19:42:17:522 [9008] DEBUG - [com.plexapp.plugins.crunchyroll] HTTP reply status 200, with 0 bytes of content.
