Plagued by Partial Recordings
Server Version#: v1.16.3.1402-22929c8a2 (server-nvidia-shield)
Player Version#: n/a
Tuner Make/Model: HD HomeRun Quattro OTA
Guide/Lineup name: n/a
Using XMLTV?: n/a
Channel number/Name: 7.1 (NBC)
About 1 out of every 10 recordings is a partial recording. A good example is this recording of NBC Nightly News with Lester Holt. It recorded just over a minute, and quit.
Could someone with a good eye for server logs take a look? I’ve truncated the logs to focus on just the timeframe in question. (17:30+).
Logs: Link to my server log
Thank you very much
It is better to upload the full logs generated from Server>Troubleshooting>Download logs.
Looks like a weak signal causing a missing segment to be (not) generated. Could also be a space/storage issue if you are writing to the internal storage.
Apr 09, 2020 17:31:47.071 [31252] DEBUG - DVR:Grabber: Signal information for tune on channel 7.1: strength: 42, quality: 67
Apr 09, 2020 17:31:47.083 [2997] DEBUG - buildLiveM3U8: min 0 max 104 ended 0
Apr 09, 2020 17:31:47.086 [4444] DEBUG - Request: [127.0.0.1:58686 (Loopback)] GET /livetv/sessions/095fc73d-c6ce-42f2-bd78-a5be434d31eb/e6f2bc6d-57e3-4f36-b3ac-675b97963e51/00104.ts (9 live) Signed-in
Apr 09, 2020 17:31:47.087 [4444] DEBUG - Content-Length of /storage/5CBCD7BFBCD791BE/NVIDIA_SHIELD/Plex-temp-transcode/Transcode/Sessions/plex-transcode-095fc73d-c6ce-42f2-bd78-a5be434d31eb/media-00104.ts is 1009560.
Apr 09, 2020 17:31:47.917 [4455] DEBUG - Transcoder segment range: 0 - 105 (105)
Apr 09, 2020 17:31:47.919 [16932] DEBUG - Completed: [127.0.0.1:58686] 200 GET /livetv/sessions/095fc73d-c6ce-42f2-bd78-a5be434d31eb/e6f2bc6d-57e3-4f36-b3ac-675b97963e51/00104.ts (10 live) 833ms 1009560 bytes (pipelined: 37)
Apr 09, 2020 17:31:47.919 [16932] DEBUG - Removed transcode data consumer, active count 1 => 0
Apr 09, 2020 17:31:48.114 [4444] DEBUG - buildLiveM3U8: min 0 max 105 ended 0
Apr 09, 2020 17:31:48.116 [2997] DEBUG - Request: [127.0.0.1:58686 (Loopback)] GET /livetv/sessions/095fc73d-c6ce-42f2-bd78-a5be434d31eb/e6f2bc6d-57e3-4f36-b3ac-675b97963e51/00105.ts (10 live) Signed-in
Apr 09, 2020 17:31:48.118 [2997] DEBUG - Content-Length of /storage/5CBCD7BFBCD791BE/NVIDIA_SHIELD/Plex-temp-transcode/Transcode/Sessions/plex-transcode-095fc73d-c6ce-42f2-bd78-a5be434d31eb/media-00105.ts is 1009936.
Apr 09, 2020 17:31:48.886 [4444] DEBUG - Transcoder segment range: 0 - 106 (106)
Apr 09, 2020 17:31:48.888 [16933] DEBUG - Completed: [127.0.0.1:58686] 200 GET /livetv/sessions/095fc73d-c6ce-42f2-bd78-a5be434d31eb/e6f2bc6d-57e3-4f36-b3ac-675b97963e51/00105.ts (10 live) 771ms 1009936 bytes (pipelined: 38)
Apr 09, 2020 17:31:48.888 [16933] DEBUG - Removed transcode data consumer, active count 1 => 0
Apr 09, 2020 17:31:48.891 [4455] ERROR - [Transcoder] [stream_segment,ssegment @ 0x2b61063c00] Failed to open segment 'media-00107.ts'
Apr 09, 2020 17:31:48.892 [2997] ERROR - [Transcoder] av_interleaved_write_frame(): No such file or directory
Apr 09, 2020 17:31:48.894 [4444] ERROR - [Transcoder] Error writing trailer of media-%05d.ts: Invalid argument
Apr 09, 2020 17:31:48.909 [16927] DEBUG - Jobs: '/data/user/0/com.plexapp.mediaserver.smb/Resources/Plex Transcoder' exit code for process 4436 is 1 (failure)
This is a plague when recording longer files like movies. No warnings, just a short file and can happen at start or end of video. It is NOT a weak signal, it is a BUG in checking for conflicts over the entire length of a scheduled recording. A WARNING icon for “Partial Recordings” should be on the thumbnail so you don’t just click and play, then it abruptly ends without any warning. This bug pisses me off.
I continue to get this problem, despite having bought a massive antenna and improved signal. There is no logic for whats going on, and this is clearly a PLEX bug. again last night on multiple shows…
Plex Media Server v1.16.3.1402-22929c8a2 - NVIDIA SHIELD Android TV darcy - build: android-aarch64 unknown - GMT -05:00
Sep 14, 2020 17:02:53.936 [28585] ERROR - [Transcoder] [stream_segment,ssegment @ 0x259f064200] Failed to open segment ‘media-00172.ts’
Sep 14, 2020 17:02:53.937 [28429] ERROR - [Transcoder] av_interleaved_write_frame(): No such file or directory
Sep 14, 2020 17:02:53.938 [28603] ERROR - [Transcoder] Error writing trailer of media-%05d.ts: Invalid argument
full logs at: http://sprunge.us/vgGgnF
Anyone have any ideas? This makes Plex into a very unreliable DVR.
