Play (the) List , playlists
Thank you, It was not showing, but I realised I was not signed into myPlex.  Once I did this Playlists showed, i did not realise Playlists where tied to My Plex within the other clients, but given its as simple as signing in I am again one happy plexconnectjunkie.
Yeah, usually Playlists are not tied to myPlex. I guess we will change that...
Could there be a option like (movie trailer/extra/audio subs) but to add a season or movie to a playlist via plexconnect? Just was curious about this as a optional feature request, I haven’t a clue on how to implement it if it were possible. :stuck_out_tongue:
will a shuffle option be added soon?
am i missing something? i tried to install that rewrite of PlayVideo.xml, new cmd {{COPY_PLAYLIST}} and i still don't get nonstop playback. is there some setting i have to change or something?
Works for me continuously.
how do I enable auto-play under playlists?
Using the latest commit from ibaa it just works. Just play a any content such as a movie or episode and it will play continuously until it runs out if content in the playlist.
Don't go through the "PrePlay Screen". Directly hit PLAY in the List-view (Playlist or Episodes). That should do the trick.
flawless!!. any plans on implementing "add to playlist" through plexconnect?
-> Post #23
No plans yet... but then there are things to do to make it nice and shiny anyways - Shuffle (with request from a pop-up menu), I don't know.
Would it be possible to view a playlist from a shared library ? I can make a playlist on pms from a shared library but I'm not able to see it on apple tv via plexconnect. Hope that makes sense !
Works for me...
Works for me...
Ok, I'll have a look again, must be something I'm not doing right, where will the playlist appear ?
Under the playlist tab to the left of the top row or do I need to enter the shared library to see it ?
Playlist tap to the left - it will (should?) show all playlists from all connected PMSs.
Ok, so definitely something is not right with my setup, I created a playlist from my own library as well to see if that would show on the Apple TV, all I get when I click the playlist tab is the spinning icon and accessing iMovie theatre message.
Logs?
Logs?
Phew , managed to sort the problem out myself, I've had the launchctl daemon installed for quite some time, I uninstalled it then reinstalled it and now the playlist is showing under the playlist tab, wasn't aware that could make a difference.
ahhh. thank you
as soon as a shuffle option is added i will sing from the rooftops and my life will be complete
