TrueNas Plugin
Server Version#:1.21.3.4015
Player Version#:4.51.1
Windows Server 2019
Server Version#:1.21.4.4054
Player Version#:4.51.3
I’ve recently upgraded my Plex on Truenas and have been seeing this playback error “Conversion failed. The transcoder exited due to an error.” frequently. I thought this was an issue with my truenas plex version so I’ve spun up a Windows server 2019 VM, but in the Windows PMS build I’m also seeing the same error. There are times I can play the same MKV and get the issue (not in the same spot) other times it works fine for over an hour. I’ve seen this error when playing music, and video. I’ve had this popup on multiple items some of which I know I have watched/listened to before without issue.
I’ve looked over the forums in regards to this error, but most of the posts were not recent to these builds. I’ve adjusted the “Library scan interval” from hourly to daily since someone said that fixed this for them. I ensure that none of the hardware acceleration was enabled to see if that would make a difference but it didn’t.
When I have seen this issue I’m local on the same network as the PMS and am the only one streaming to a PC Plex Web Player.
I’ve tried the following players
- Local Web Player
- App.Plex.tv Web Player
- Plex PC Client
The Attached Log is from Plex running on TrueNas
Plex Media Server Logs_2021-02-19_21-17-58.zip (2.9 MB)
