Playback error on Sony Bravia Android TV since update
Server Version#: Tried with 1.14.1.5488 and 1.15.2. 793
Player Version#: 7.12.2.9471
Android Version#: 7.0
After an update of the Plex app on my Sony Bravia 4K Android TV, I cant play any files, everytime I get the message “Playback has stopped because the connection to the Plex Media Server has been lost.”.
I tried restoring my TV to default settings, downgrading PMS, reinstalling Plex on my TV.
I’m out of option, some help would be awesome! I can provide logs if you tell me how!
Thnak you!
Edit: Uploaded the log file from PMS
Plex Media Server Logs_2019-03-21_14-14-59.zip (1.3 MB)
Edit 2: When I monitor the console, the only Warning I see is this one:
Got a request to stop a transcode session without a session GUID (or with an invalid one).
Anyone from Plex? I’m available to troubleshoot and find the root cause.
I’m having the same issue. I also have a Sony Bravia TV.
There seems to be no support at all, I don’t know where to ask, I’ve tried here and Reddit…
same issue but on my nvidia shields AND my ios devices.
went through hell troubleshooting and now its looking like its not on my end anyhow.
I’m getting the same issue. I can watch media from ios, and pc, and web remotely - but on the TV itself, I am getting the “Playback has stopped” error. The logs show the following.
03-29 18:53:21.282  i: [FF][MediaPeriod] Releasing.
03-29 18:53:21.285  i: [FF] Releasing demuxer.
03-29 18:53:21.285  e: [Exo2VideoPlayer] Player error detected
03-29 18:53:21.286  e: An exception occurred: com.google.android.exoplayer2.ExoPlaybackException: java.lang.IllegalStateException
03-29 18:53:21.286  i: [FFmpeg] Demuxer closing.
03-29 18:53:21.286  e: Stacktrace: com.google.android.exoplayer2.ExoPlaybackException: java.lang.IllegalStateException
	at com.google.android.exoplayer2.m.handleMessage(SourceFile:359)
	at android.os.Handler.dispatchMessage(Handler.java:101)
	at android.os.Looper.loop(Looper.java:164)
	at android.os.HandlerThread.run(HandlerThread.java:65)
Caused by: java.lang.IllegalStateException
	at android.media.MediaCodec.native_dequeueOutputBuffer(Native Method)
	at android.media.MediaCodec.dequeueOutputBuffer(MediaCodec.java:2622)
	at com.google.android.exoplayer2.mediacodec.MediaCodecRenderer.a(SourceFile:1287)
	at com.google.android.exoplayer2.mediacodec.MediaCodecRenderer.render(SourceFile:663)
	at com.google.android.exoplayer2.m.h(SourceFile:536)
	at com.google.android.exoplayer2.m.handleMessage(SourceFile:303)
	... 3 more
03-29 18:53:21.314  i: [video] Error detected before playback
03-29 18:53:21.325  i: [FF] ********************************************************
[FF] Statistics:
State: Buffering Loading: Yes Auto Play: Yes
Surface: None
Position:  0:00 Duration: 43:37
Window Start:  0:00 Window End: 43:37 Position in Period:  0:00
Period Position:  0:00 Period Duration: -27:-57
Video:Unknown
Audio:Unknown
Memory Usage: 399.8789 / 1583.4961 Threshold: 192.1875.
03-29 18:53:21.331  i: Fetching [method:GET] https://192.168.1.149:32400/:/timeline?bandwidth=44152&bufferedTime=0&containerKey=%2FplayQueues%2F3710&duration=2617000&guid=com.plexapp.agents.thetvdb%3A%2F%2F299139%2F4%2F9%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F48948&location=lan&machineIdentifier=6619c84a2b781a436ded8156a
03-29 18:53:21.360  i: [Exo2VideoPlayer] Player has already been stopped.
03-29 18:53:21.360  i: [TranscodeSession] Stopping...
03-29 18:53:21.363  e: [Video Player] A recoverable error occurred while attempting to play: /library/metadata/48948.
03-29 18:53:21.363  e: [Video Player] Playback has stopped because the connection to the Plex Media Server has been lost. Please ensure the server is available and retry.
03-29 18:53:21.364  i: [Video Player] Showing retry playback dialog.
Same problem here , impossible to found the server .
I found a way to show my server forcing the ip of my TV in the plex server setup but i can’t play any video, movie, music etc
It works well on all others (xbox, pc, phone, etc)
someone know something about that problem ?
I’m getting this error on my XF90: “An error occurred while attempting to play this video. Please try restarting both the Plex Media Server and this app”. I reinstalled the server and rebuilt the library. Worked for a couple days and now the problem is back. I’ve seen old topics on this problem, tried the suggestions in there but none of them fixed it. Pretty big waste of time having to reinstall and rebuild all libraries just for a few days of functionality.
im having the same issue. please fix this/
Just bought a new Sony TV primarily for Plex, and haven’t been able to use it.
Same problem!
I guys, its seems than I have the same issue too.
If I launch a media from my shield the file launch itself but I have some lag until the file just stop (Playback has stopped).
However, if I launch the exact same files from my Iphone and cast it on my shield then there’s no problem…Honestly that’s weird, I hope someone can help us.
