Server Version#: 1.43.1.10611
Player Version#:10.30.9.4262 (067590FF)
I have a Firestick 4k max gen2 plugged directly into a Denon X3700h AV receiver (with the included hdmi extender that came in the box).
I have been experiencing issues primarily with HEVC videos but it also to a lesser degree affects H264 videos. A lot of media I watch are 4K HDR or Dolby Vision, many of these have multi channel EAC3 audio with dolby atmos. I’ve experienced patchy behaviour on both .mkv and .mp4 containers.
Behaviour 1: If the media is 4K HEVC has EAC3 and has a subtitle track enabled (most commonly .srt) then it will often display error message “Unable to play media”. However on the odd occasion it will direct play fine with no issue.
Behavior 2: If the media is 4K HEVC has EAC3 audio with no subtitle track selected, then it will sometimes display “An Error occurred while attempting to play this video. Please check your connection and try again.” Now when this happens often the TV has triggered dolby vision mode, spam clicking the “OK” button to try again quickly will often make the video direct play but PLEX will use the c2.dolby.eac3.decoder on the audio which seems to decode the audio to stereo and you lose the atmos information.
Now sometimes it will transcode, it will say that direct play was attempted but failed and it is falling back to transcoding. Sometimes it will say copy(hevc), copy(eac3), but sometimes it will do a hevc → h264 transcode. Fixing this is relatively simple - you enable subtitles (or flick it on an off) and it will magically direct play without needing to exit the player.
On the odd occasion it will direct play fine with no issues. However I will point out that I also get this error with 4K HEVC with AC3 audio too with same behaviours exhibited.
Behaviour 3: on very rare occasions I’ve found direct playing constantly drop frames or subtitles not displaying which required a restart of the firestick, I’ve only had to do this twice.
Now TRUEHD audio seems to be a bit better behaved, it won’t fail out right but video may fall back to transcoding and may need the quick fix of enabling or disabling or switching subtitles. The same goes for DTS audio. However other formats like FLAC and OPUS will direct play with no issues, I’ve never encountered falling back to transcoding or an error message with other audio formats with or without subtitles enabled. I also created a 4K HEVC file with subs but no audio and this also direct played with no issues, with or without subs enabled.
Things also seem much better behaved when switching directly between episodes or using the continue watching screen at the end of an episode to watch the next one.
I have tried HEVC video with EAC3 stereo audio, I’ve never seen it fail outright but it will often fall back to transcoding before fixing itself if you flick the subtitles.
HEVC files have a risk of failing to play outright but when playing back h264 files with eac3 audio I also sometimes find it falls back to transcoding and requires enabling or disabling or switching sub tracks to fix it and make it direct play.
