I have a small issue with playback, where throughout movies and tv shows, playback glitches and stutters a few seconds multiples times through the movie or tv show.
but it doesn’t do it on my iPhone, MacBook or iPad, just on the Apple TV.
most of my content is a mix of 720 and 1080p mkv and mp4 h264 and h265
what can I do to stop the issue?
thanks,
tom80H
December 29, 2022, 4:48pm
2
basic troubleshooting steps:
Check out the “now playing” tile for the stream on the Plex server dashboard?
Is the stream listed as Local, Remote or Indirect?
Local streams should be recognized as Local. If your Apple TV is on a different subnet, the server and client will apply settings for remote streaming (e.g. bandwidth limits or quality preferences)
Remote streams should be recognized as Remote. If there’s an issue with the remote access setup, the stream might be indirect/relayed which applies further restrictions (indirect streams are routed through some Plex relay servers which only offer a 1 Mbps bandwidth; 2 Mbps for Plex Pass members).
Is there any transcoding for the video/audio/subtitle tracks of your stream?
transcoding could exceed the capabilities of the Syno’s CPU
verify if HW accelerated transcoding is supported and if it’s working properly
https://support.plex.tv/articles/200871837-status-and-dashboard/
Right now I have my son watching SpongeBob
And it shows direct play.
And my friend watching bob’s burgers that lives about 4 hours away from me.
Both show direct play
As I was watching a movie, Iron Man 2
Several times it’s was stuttering during some scenes, I had subtitles on and turned off subtitles and replayed the scene and it played without stuttering.
So I am thinking it has something to do with subtitles.
tom80H
December 30, 2022, 9:30pm
5
If those subtitles cannot be played by the client as-is, your server will burn them into the video. That’s a job which cannot be outsourced to the GPU, so it’ll be up to how powerful the CPU of that Syno is.
The subtitles are .srt
All of my subtitles are in the same format.
ChuckPa
December 31, 2022, 2:08am
7
May I see the PMS DEBUG Server logs ZIP file which captures one of these playbacks?
The logs will definitively show what is or isn’t happening.
At this point, there are still several unanswered questions.
ChuckPa
December 31, 2022, 2:33am
9
Which video playback am I looking at ‘Prom Night’ ?
ChuckPa
December 31, 2022, 2:36am
10
Transcoder is ahead of playback needs so going into ‘Sloth mode’ (it slows down the output but stays active
Dec 30, 2022 21:27:39.780 [0x7f65113f9b38] DEBUG - Completed: [127.0.0.1:50322] 206 PUT /video/:/transcode/session/3F512056-C087-4CF0-8CF2-620F82FB3D5F/91271f00-f672-4659-ae7d-f9c03d0deb39/progress?progress=17.3&size=-22&remaining=-1&speed=433.8 (19 live) 0ms 371 bytes (pipelined: 23) (range: bytes=0-)
Dec 30, 2022 21:27:39.780 [0x7f64db065b38] DEBUG - Request: [127.0.0.1:50322 (Loopback)] POST /video/:/transcode/session/3F512056-C087-4CF0-8CF2-620F82FB3D5F/91271f00-f672-4659-ae7d-f9c03d0deb39/progress/log?level=3&message=Throttle%20-%20Going%20into%20sloth%20mode. (19 live) #67e12e Signed-in Token (PatrickWhalen) (range: bytes=0-)
Dec 30, 2022 21:27:39.780 [0x7f64db065b38] DEBUG - [Req#67e12e/Transcode/3F512056-C087-4CF0-8CF2-620F82FB3D5F/91271f00-f672-4659-ae7d-f9c03d0deb39] Throttle - Going into sloth mode.
Dec 30, 2022 21:27:39.780 [0x7f65115fcb38] DEBUG - Completed: [127.0.0.1:50322] 200 POST /video/:/transcode/session/3F512056-C087-4CF0-8CF2-620F82FB3D5F/91271f00-f672-4659-ae7d-f9c03d0deb39/progress/log?level=3&message=Throttle%20-%20Going%20into%20sloth%20mode. (19 live) 0ms 195 bytes (pipelined: 24) (range: bytes=0-)
Dec 30, 2022 21:27:40.384 [0x7f64da0aab38] DEBUG - Request: [127.0.0.1:50322 (Loopback)] PUT /video/:/transcode/session/3F512056-C087-4CF0-8CF2-620F82FB3D5F/91271f00-f672-4659-ae7d-f9c03d0deb39/progress?progress=17.3&size=-22&remaining=-1 (19 live) #67e12f Signed-in Token (PatrickWhalen) (range: bytes=0-)
Dec 30, 2022 21:27:40.384 [0x7f65113f9b38] DEBUG - Completed: [127.0.0.1:50322] 206 PUT /video/:/transcode/session/3F512056-C087-4CF0-8CF2-620F82FB3D5F/91271f00-f672-4659-ae7d-f9c03d0deb39/progress?progress=17.3&size=-22&remaining=-1 (19 live) 0ms 371 bytes (pipelined: 25) (range: bytes=0-)
Dec 30, 2022 21:27:40.887 [0x7f64da0aab38] DEBUG - Request: [127.0.0.1:50322 (Loopback)] PUT /video/:/transcode/session/3F512056-C087-4CF0-8CF2-620F82FB3D5F/91271f00-f672-4659-ae7d-f9c03d0deb39/progress?progress=17.3&size=-22&remaining=-1 (19 live) #67e130 Signed-in Token (PatrickWhalen) (range: bytes=0-)
Dec 30, 2022 21:27:40.887 [0x7f65115fcb38] DEBUG - Completed: [127.0.0.1:50322] 206 PUT /video/:/transcode/session/3F512056-C087-4CF0-8CF2-620F82FB3D5F/91271f00-f672-4659-ae7d-f9c03d0deb39/progress?progress=17.3&size=-22&remaining=-1 (19 live) 0ms 371 bytes (pipelined: 26) (range: bytes=0-)
Dec 30, 2022 21:27:41.390 [0x7f64d8c1eb38] DEBUG - Request: [127.0.0.1:50322 (Loopback)] PUT /video/:/transcode/session/3F512056-C087-4CF0-8CF2-620F82FB3D5F/91271f00-f672-4659-ae7d-f9c03d0deb39/progress?progress=17.3&size=-22&remaining=-1 (19 live) #67e135 Signed-in Token (PatrickWhalen) (range: bytes=0-)
Dec 30, 2022 21:27:41.390 [0x7f65113f9b38] DEBUG - Completed: [127.0.0.1:50322] 206 PUT /video/:/transcode/session/3F512056-C087-4CF0-8CF2-620F82FB3D5F/91271f00-f672-4659-ae7d-f9c03d0deb39/progress?progress=17.3&size=-22&remaining=-1 (19 live) 0ms 371 bytes (pipelined: 27) (range: bytes=0-)
Dec 30, 2022 21:27:41.837 [0x7f64da0aab38] DEBUG - Request: [10.0.0.181:64852 (Subnet)] GET /:/timeline?bufferedTime=216&col=1&context=preplay&duration=1350808&key=%2Flibrary%2Fmetadata%2F108156&location=lan&playQueueItemID=20489&playbackTime=5017&ratingKey=108156&row=0&state=playing&time=4867 (19 live) #67e043 TLS GZIP Signed-in Token (PatrickWhalen) (Apple TV)
Dec 30, 2022 21:27:41.838 [0x7f64da0aab38] DEBUG - [Req#67e043] Client [9ABE0CB6-90AE-4D0B-8D07-0F44CAB97F5F] reporting timeline state playing, progress of 4867/1350808ms for guid=, playbackTime=5017ms ratingKey=108156 url=, key=/library/metadata/108156, containerKey=, metadataId=108156, source=
Dec 30, 2022 21:27:41.838 [0x7f64da0aab38] DEBUG - [Req#67e043] [Now] User is PatrickWhalen (ID: 1)
Dec 30, 2022 21:27:41.839 [0x7f64da0aab38] DEBUG - [Req#67e043] [Now] Device is tvOS (Apple TV).
Dec 30, 2022 21:27:41.839 [0x7f64da0aab38] DEBUG - [Req#67e043] [Now] Profile is tvOS
Dec 30, 2022 21:27:41.839 [0x7f64da0aab38] DEBUG - [Req#67e043] [Now] Updated play state for /library/metadata/108156.
Dec 30, 2022 21:27:41.839 [0x7f64da0aab38] DEBUG - [Req#67e043] Statistics: (9ABE0CB6-90AE-4D0B-8D07-0F44CAB97F5F) Reporting active playback in state 0 of type 4 (scrobble: 0) for account 1
Dec 30, 2022 21:27:41.842 [0x7f65115fcb38] DEBUG - Completed: [10.0.0.181:64852] 200 GET /:/timeline?bufferedTime=216&col=1&context=preplay&duration=1350808&key=%2Flibrary%2Fmetadata%2F108156&location=lan&playQueueItemID=20489&playbackTime=5017&ratingKey=108156&row=0&state=playing&time=4867 (19 live) TLS GZIP 5ms 770 bytes (pipelined: 27)
Dec 30, 2022 21:27:41.893 [0x7f64d8c1eb38] DEBUG - Request: [127.0.0.1:50322 (Loopback)] PUT /video/:/transcode/session/3F512056-C087-4CF0-8CF2-620F82FB3D5F/91271f00-f672-4659-ae7d-f9c03d0deb39/progress?progress=17.3&size=-22&remaining=-1 (19 live) #67e136 Signed-in Token (PatrickWhalen) (range: bytes=0-)
Dec 30, 2022 21:27:41.894 [0x7f65113f9b38] DEBUG - Completed: [127.0.0.1:50322] 206 PUT /video/:/transcode/session/3F512056-C087-4CF0-8CF2-620F82FB3D5F/91271f00-f672-4659-ae7d-f9c03d0deb39/progress?progress=17.3&size=-22&remaining=-1 (19 live) 0ms 371 bytes (pipelined: 28) (range: bytes=0-)
Dec 30, 2022 21:27:42.397 [0x7f64d433bb38] DEBUG - Request: [127.0.0.1:50322 (Loopback)] PUT /video/:/transcode/session/3F512056-C087-4CF0-8CF2-620F82FB3D5F/91271f00-f672-4659-ae7d-f9c03d0deb39/progress?progress=17.3&size=-22&remaining=-1 (19 live) #67e13c Signed-in Token (PatrickWhalen) (range: bytes=0-)
Dec 30, 2022 21:27:42.397 [0x7f65115fcb38] DEBUG - Completed: [127.0.0.1:50322] 206 PUT /video/:/transcode/session/3F512056-C087-4CF0-8CF2-620F82FB3D5F/91271f00-f672-4659-ae7d-f9c03d0deb39/progress?progress=17.3&size=-22&remaining=-1 (19 live) 0ms 371 bytes (pipelined: 29) (range: bytes=0-)
The issue was with iron man 2
ChuckPa
December 31, 2022, 3:29am
12
Why is your scanner firing so much?
It seems to be almost in a constant loop ?
Do you have other programs writing into the media area ?
Every 20 minutes?
Plex Media Server.1.log:Dec 30, 2022 20:40:15.397 [0x7f64daa5cb38] DEBUG - Scanner: Processing directory /volume1/data/media/movies/movies/Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265) (parent: yes)
Plex Media Server.1.log:Dec 30, 2022 20:40:15.397 [0x7f64daa5cb38] DEBUG - Skipping over directory 'Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265)', as nothing has changed; removing 1 media items from map.
Plex Media Server.1.log:Dec 30, 2022 21:00:15.301 [0x7f64d952ab38] DEBUG - Scanner: Processing directory /volume1/data/media/movies/movies/Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265) (parent: yes)
Plex Media Server.1.log:Dec 30, 2022 21:00:15.301 [0x7f64d952ab38] DEBUG - Skipping over directory 'Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265)', as nothing has changed; removing 1 media items from map.
Plex Media Server.2.log:Dec 30, 2022 20:00:15.264 [0x7f64d9ea7b38] DEBUG - Scanner: Processing directory /volume1/data/media/movies/movies/Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265) (parent: yes)
Plex Media Server.2.log:Dec 30, 2022 20:00:15.264 [0x7f64d9ea7b38] DEBUG - Skipping over directory 'Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265)', as nothing has changed; removing 1 media items from map.
Plex Media Server.2.log:Dec 30, 2022 20:20:15.092 [0x7f64dbda8b38] DEBUG - Scanner: Processing directory /volume1/data/media/movies/movies/Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265) (parent: yes)
Plex Media Server.2.log:Dec 30, 2022 20:20:15.093 [0x7f64dbda8b38] DEBUG - Skipping over directory 'Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265)', as nothing has changed; removing 1 media items from map.
Plex Media Server.3.log:Dec 30, 2022 19:20:15.264 [0x7f64dcafbb38] DEBUG - Scanner: Processing directory /volume1/data/media/movies/movies/Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265) (parent: yes)
Plex Media Server.3.log:Dec 30, 2022 19:20:15.265 [0x7f64dcafbb38] DEBUG - Skipping over directory 'Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265)', as nothing has changed; removing 1 media items from map.
Plex Media Server.3.log:Dec 30, 2022 19:40:15.303 [0x7f64dbb85b38] DEBUG - Scanner: Processing directory /volume1/data/media/movies/movies/Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265) (parent: yes)
Plex Media Server.3.log:Dec 30, 2022 19:40:15.303 [0x7f64dbb85b38] DEBUG - Skipping over directory 'Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265)', as nothing has changed; removing 1 media items from map.
Plex Media Server.4.log:Dec 30, 2022 18:40:18.286 [0x7f64d9ea7b38] DEBUG - Scanner: Processing directory /volume1/data/media/movies/movies/Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265) (parent: yes)
Plex Media Server.4.log:Dec 30, 2022 18:40:18.287 [0x7f64d9ea7b38] DEBUG - Skipping over directory 'Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265)', as nothing has changed; removing 1 media items from map.
Plex Media Server.4.log:Dec 30, 2022 19:00:15.285 [0x7f64dc407b38] DEBUG - Scanner: Processing directory /volume1/data/media/movies/movies/Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265) (parent: yes)
Plex Media Server.4.log:Dec 30, 2022 19:00:15.285 [0x7f64dc407b38] DEBUG - Skipping over directory 'Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265)', as nothing has changed; removing 1 media items from map.
Plex Media Server.5.log:Dec 30, 2022 18:00:15.137 [0x7f64da6e2b38] DEBUG - Scanner: Processing directory /volume1/data/media/movies/movies/Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265) (parent: yes)
Plex Media Server.5.log:Dec 30, 2022 18:00:15.137 [0x7f64da6e2b38] DEBUG - Skipping over directory 'Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265)', as nothing has changed; removing 1 media items from map.
Plex Media Server.5.log:Dec 30, 2022 18:20:15.407 [0x7f64daa5cb38] DEBUG - Scanner: Processing directory /volume1/data/media/movies/movies/Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265) (parent: yes)
Plex Media Server.5.log:Dec 30, 2022 18:20:15.407 [0x7f64daa5cb38] DEBUG - Skipping over directory 'Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265)', as nothing has changed; removing 1 media items from map.
Plex Media Server.log:Dec 30, 2022 21:20:15.089 [0x7f64dc317b38] DEBUG - Scanner: Processing directory /volume1/data/media/movies/movies/Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265) (parent: yes)
Plex Media Server.log:Dec 30, 2022 21:20:15.089 [0x7f64dc317b38] DEBUG - Skipping over directory 'Iron Man 2 (2010) {imdb-tt1228705} (1080p) (h265)', as nothing has changed; removing 1 media items from map.
[chuck@lizum user.2013]$
I don’t see any playback sessions for Iron Man 2
The only programs I use are Sonarr and Radarr
I have no idea why it’s always scanning.
ChuckPa
December 31, 2022, 3:48am
14
Settings - Server - Library - Show advanced.
Do you have a Scan interval of 20 minutes ?
Do you have Partial Scan enabled ?
yes have both set up.
I have it set to scan every 15 mintutes, not 20.
ChuckPa
December 31, 2022, 4:00am
16
This the right server?
Timestamps are: 18:00, 18:20, 18:40, 19:00, 19:20, 19:40, 20:00, 20:20. and 20,40
I am not sure.
I know I am on another persons server.
But never watch anything there.
I think I found a solution, in the Apple TV Plex app settings I selected use old media player and when I tried to play a movie that would stutter it no longer stutters.
