Server Version#:1.42.2.10.156
Player Version#:4.12.4
Everything works on v4.11 - switch to v4.12 and above, I run into issues.
If I stream I can adjust playback speed slow or fast and it works as expected.
Download some albums and it works fine.
Download a playlist and if I try adjusting playback speed, nothing happens?
I did a complete reset on my Samsung A34 - installed latest Plexamp, imported playlist but still cannot get playback speed to work?
Jan 12, 2026 11:23:57.339 [0x17fc33c0] DEBUG - Opus: Successfully seeked to 2691360 samples.
Jan 12, 2026 11:23:57.339 [0x17fc33c0] DEBUG - BASS: Initial mixer offset 56.1 sec.
Jan 12, 2026 11:23:57.339 [0x17fc33c0] DEBUG - Opus: Bitrate is 227498
Jan 12, 2026 11:23:57.339 [0x17fc33c0] INFO - BASS: Opened stream 1768209001534 in 31 ms (paused: 1) with gain 0.0 dB, max 0 Kbps (picked opus, 256 Kbps, actual 227 Kbps/sec).
Jan 12, 2026 11:23:57.339 [0x17fc33c0] INFO - BASS: Created a gapless source stream for 1768209001534 (channel: 0x8000000a) with sample rate of 48000 and 2 channels (paused: 1)
Jan 12, 2026 11:23:57.339 [0x17fc33c0] DEBUG - BASS: Creating resampler for rate 1.1.
Jan 12, 2026 11:23:57.340 [0x17fc33c0] ERROR - BASS: Error [BASS_ChannelSetDevice(m_resampler, BASS_NODEVICE)] - 5
Jan 12, 2026 11:23:57.340 [0x17fc33c0] ERROR - BASS: Error [BASS_ChannelSetAttribute(m_resampler, BASS_ATTRIB_TEMPO_OPTION_USE_QUICKALGO, 1)] - 5
Jan 12, 2026 11:23:57.340 [0x17fc33c0] ERROR - BASS: Error [BASS_ChannelSetAttribute(m_resampler, BASS_ATTRIB_TEMPO_OPTION_PREVENT_CLICK, 1)] - 5
Jan 12, 2026 11:23:57.341 [0x191bf3c0] DEBUG - Cache: Locking 944b83f7fc683e017f7adf83ef0064eef4c7c3be19ef500c349e7e94e5370d90 (count=1), now in use 2.
Jan 12, 2026 11:23:57.347 [0x191bf3c0] DEBUG - Cache: Assimilating metadata for file with bitrate 256 kbps.
Jan 12, 2026 11:23:57.350 [0x191bf3c0] INFO - Cache: Opened cache file with 7806511 bytes (of 7806511 total) at ‘/data/user/0/tv.plex.labs.plexamp/files/Offline/56192f5a376c3c0af2302c5bed6634300edcea57f399225b4326e08e9580982a/6e86cdd2d68c39135bf56e73ef359e5e34ad5939b42eeaaed6a5b151c73e7ae2’.
Jan 12, 2026 11:23:57.350 [0x191bf3c0] INFO - Cache: Using RAM buffer of 2048 KB for item with container ogg bitrate of 32 KB/sec.
Jan 12, 2026 11:23:57.351 [0x191bf3c0] DEBUG - Cache: Fully cached, not going into buffering state.
Jan 12, 2026 11:23:57.351 [0x191bf3c0] INFO - PQCache: Set item 1768209001538 active to 0, 0 active remaining.
Jan 12, 2026 11:23:57.351 [0x191bf3c0] DEBUG - Cache: Caching completed, notifying observer.
Jan 12, 2026 11:23:57.351 [0x191bf3c0] INFO - BASS: Stream 1768209001538 completed caching.
