Playlist Length
I haven’t seen anything about this in the forums. My issue is, I’m creating music playlists that are pretty long (9 hours or more) for shuffling purposes. After about 2 hours or so, the playlist will stop as if it has reached the end of the playlist. This happens every time with every playlist created. Playlists are being played on the XBox One. What am I doing wrong? Any help would be appreciated.
It’s probably the issue that unless you scroll through the entire playlist after going into it, then the app only selects from the first 50 items ONLY, and will finish when it goes through all of those first 50 items.
So, when you say to scroll through, you literally just need to scroll down the entire list to the end before pressing play\shuffle?
Yes. If you do that, it will shuffle through all of the items. At least, it has for me so far.
But you need to do that EVERY TIME you use that playlist.
has anyone had an issue with re-positioning songs?
when i try to move a song up or down, it stays in the same place
