Playlist Sort - please let us add items to a playlist and then sort by original air date. This allows you to put multiple shows together that have crossovers!
Dumb playlists don’t have a sort option. You can just manually move then around the way you want.
If you create a Smart Playlist, that can be sorted by the aired date.
There is a feature request where you may want to add your vote.
You can do this with Smart Playlists. Under Advanced Filters you can pick Release Date. You could use a Smart Collection to package the shows together, but imo that’s an un-needed extra step.
g)
