Are playlists not supported on PlexConnect for the ATV2 version 6.2.1? I've created playlists on my PMS for continuous play, they show on all devices except the ATV2. There's not even a playlist option/tab. Am I missing something or doing something wrong, or is the playlist feature only available for the ATV3.
Liking your own posts, that is something. :-)
Anyways, a playlists tab should show up left of Library. Check your settings - is it hidden?
Baa,
Thanks for your reply, I have checked and rechecked, the only tabs I get are Library, Channels, Shared Libraries and Settings and nothing in the setting tab mentions anything in reference to Playlists, perhaps it’s in another version of PlexConnect?
>>perhaps it's in another version of PlexConnect?
I typically think, you guys run the latest - especially if not told otherwise. If yours is like years old, I really can't remember the features installed at that point in time. :-D
I actually loaded it up roughly around the middle of last month.
Where from?
Telling the version might still be helpfull...
Plus -> https://forums.plex.tv/topic/69410-read-before-posting/
