Plex 1.26.0.5715 and Rasplex
Server Version#: 1.26.0.5715
Player Version#:1.8.0.148
Plex server is installed on Synology DSM since many years, works fine.
I use 2 players : a Windows computer and a RasPlex.
I have upgraded the server to 1.26.0.5715 last week.
Since the upgrade, the client Windows works correctly, but the Rasplex doesn’t display any library.
What did change in this Plex Server version that could block the RasPlex ?
Thanks for your help.
For what it’s worth I had the same issue. Can’t recall which upgrade version finally did it. But as Rasplex hasn’t been updated in years, I had seen more and more issues over time. This was the final one for me and I have retired the 3 rasplex Pi’s that I was using…
I have the same issue on my Ubuntu install, the web app working but an unexpected error on libraries. Rolled back to 1.25.7.5604 and working as normal
