Thanks @croneter - I am keen to keep the Plex look and feel. Been using it for years. Is that possible? I had looked at PKC but really wanted to stick with Plex - just updated more often?
You can customize Kodi to your liking with different skins. I’m not aware though that there is a skin imitating Plex. I personally use Arctic Zephyr and like it a lot
My nephew sorted a temp fix while he figures out a permanent solution. A variable has been removed from a server response when transcoding is required and it breaks the add on.
Does it support Collection ? It’s the only thing that is really missing for me with the original addon
And by the way, what are the differences with yours ?
