Plex always says running database migrations only for TV library when running PMM
Server Version#: 1.40.0.7775
I’m on Unraid 6.12.3 using binhex-plexpass docker and using Plex Meta Manager 1.2
PMM runs at 5am everyday, it worked fine for a year. Now the PMM logs show: (503) service_unavailable; (redacted)/library/sections/2/all?id=63969&label.locked=1&label%5B%5D.tag.tag-=Overlay&type=4 <?xml version="1.0" encoding="utf-8"?>
So it won’t apply any overlays and It only does this for the TV Show library. The Movie library works without issue.
I have tried running PMM for the TV library at every time of day and Plex always gives the “running database migrations”. This has been ongoing for months. I have tried ChuckPA DBRepair and it says DB is ok. Not sure what else to try
Might want to check with the PMM developers.
PMS 1.40 has database changes. PMM may not be compatible.
They said its not PMM since its plex telling PMM its unavailable.
