Plex Amp playlist max size?
Hi all.
I have a Tidal playlist that is just under 7000 songs, it loads for a while then gives up. Is there a max playlist size?
Sorry, this issue is fixed in the next release.
Thank you, I will await the next release.
Just an FYI this still isn’t working on the latest version. All the Tidal playlists work except the very large one. It just gives up after about 30 seconds of trying.
