I recently heard about the Plex Amp app for music listening, while watching Byte my Bits on YouTube. I loaded it onto my android and it performs very well, minus one thing that will pretty much prevent me from using it without a lot of work on my part for re-organizing my library from within the server. Under the Library tab, there is not a function that allows you to access music from a given folder, and with plex being on my windows machine, organizing by folder is the easiest way to keep things straight. I have been playing music from my plex mobile app while in the car or at work, but i’m thinking the Plex Amp app is going to be way better for this type of mobile file access. The biggest issue that I have right now without having folder access, the app blends my music, audio books, and old time radio shows all together and my “favorites” folder is in there but just blended in with everything else. Trying to build a playlist in Plex with the 4000 plus songs i have in my favorites folder will take hours of selecting to put in the playlist. Basicly it means reconfiguring everything, and then it doesnt work well with my home network sharing, OR it means countless hours IN plex creating playlists. A simple folders option under the library menu would make things a lot easier for those of us that extensively use folders in our organization. Just my 2 cents, i’m not a programmer, so don’t understand how much extra work it would mean to add this feature, but I can tell you, i would be done with all of the other streaming services if this one feature was included with Plex Amp. Beyond that, this app looks awsome, does a lot of really cool interactive things, and connects to my server even better than the plex mobile app that i have on the same android. Keep up the good work Plex team, and hopefully, my issue is an easy adjustment on your side?
Server Version#:
