Server Version#:1.28.2.6151-914ddd2b3
Player Version#:1.25.1 (Plex htpc) 1.53.1 (Plex for linux)
I have just upgraded my ubuntu distro from 20.04 LTS to 22.04.1 LTS, and the plex applications do not launch anymore.
I have seen others posts on reddit and snap store with the same issue (since last may for plex htpc and september for plex for linux), is there a way to make it work or is plex not compatible with 22.04 LTS?
Thanks, have a nice day
JB
Most likely wayland vrs x11. I’m running x11 with ubuntu 22.04 and they run perfectly.
Search the forum, this has come up a few times.
Hi, thanks a lot for your message Dokuro, that did the trick.
My bad, I searched the forum for an answer but not intensively enough.
I changed my settings to automatically start on Xorg instead of Wayland!
Cheers!
