Plex app for Panasonic Smart Viera
@lolouk44 no need for the index.html copy all but index.html to /var/www/html
@ClosestStorm Thank you so much for doing this. I tried running the script on my Qnap NAS and it appears to work as expected. One thing I may try and change is allowing a port in the redirect in dns.conf.
Surely there must be a way of getting an app on the Panasonic Store rather than re-directing through lifeshow!
I’ve tried App Store I got the site for market but it’s says request rejected, life show player it’s great for time being I’ve always got my sinology Nas running anyway, plus don’t have the 6 month Panasonic free sdk limit.
Did they give any explanation as to why it was rejected? Wonder if forwarding it to the Plex team and asking them to step in provide you ā€œauthorityā€ to publish an unofficial release would help?
@KuDoZ83 rejected access link when I tried accessing it from a pc through I could do a redirect to make Plex installable instead of having dns method running 24/7, Plex should put it on app market Panasonics the only tv make that doesn’t have Plex
Can everyone like and share this Twitter post @plex to see if we can properly get their attention?
@KuDoZ83 retweeted your post I’ve try getting their attention already mind through twitter, have you tried my dns method better then side loading
Hi @ClosestStorm
just want to update myself to the current state :wink:
What’s working right now? Is the app now in fullscreen, without the boarders? Or is it still the workaround with the intercepting webserver?
And if you like, you could contact Elan (elan@plex.tv). He’s pretty cool when it comes to something like this ^^
@shippi said:
Hi @ClosestStorm
mapping domain of a app to local my nas.through DNS, I’ve made a docker container only 50 meg. or just need python to run it. working very well I’ll msg you a video
@ClosestStorm said:
@shippi said:
Hi @ClosestStorm
I hadn’t gotten around to trying the DNS option yet actually, but would love to give your docker container a go (I just redid my whole NAS based on linux.io docker images)
@KuDoZ83 I’ll up to it for you tomorrow and message you a link
made ajustment to my Plex url ā€˜http://plex.rbrit.org’ for html5 sdk browser mouse no longer appears after redirect
Hi ClosestStorm, I was able to host those files myself and browse to them using the Panasonic App Development browser thing and it worked. Is it possible to get it to work as standalone app now? and how :slight_smile:
@maui1911
theres a standalone app but only works for hd tv’s. I have come up with a dns method that redirects one app to plex instead.
@ClosestStorm said:
@jco23 said:
i used the http://plex.tv/web/tv/generic link, and was able to login into Plex. it works, but wish I could get a FULL screen (hiding the navigation pane at the top and scroll bars). any ideas?
the http://plex.tv/web/tv/lg link cuts off for me like mcgyver83 pictured.
the https://plex.rbrit.org simply re-routes to the http://plex.tv/web/tv/lg link.
as of now, I’m just using chromecast, but would prefer this to work.
thanks to all!
doen’t just reroutes it uses the init.json script before it reroutes and the top bar you need install web clip with firefox web ide’s from my git GitHub - ClosestStorm/PlexTVFirefoxOS: PlexTV App for FirefoxOS it only works on HD not 4k
Hi @ClosestStorm,
i’ve a TX-50CX700 tv . how can i install your app on my tv?
i’ve dowloaded your PlexTV FFOS 4k.zip file , have i to installa in the tv thorught the developer app?
thanks a lot for the support
@jco23 sorry 4k zip doesn’t work on 4k forgot to remove from it you’ll haft to use redirect method GitHub - ClosestStorm/panasonic-plex-dns or load this page on Panasonic iptv html5 sdk plex.rbrit.org installing the zip only work hd :frowning: but dns methods good I just run it on same machine as my Plex
thanks , but i’ve to change the dns in the general settings of the tv or only in the app?
how i can install LifeShow Player , is there in the market ?
thanks a lot
@supermik84 yeh lifeshow player is on store then put the ip of the computer your running the python script on
pardon me but my limited english and knowledge about python and stuff make the thing difficult to me.
I’d love install plex on my panasonic tv, really … I need it !!!
it is possible to explain with some simple steps the way to do ?
im on Mac Os et Panasonic 4K (750dx700)
thank you so much !
@fabthebass said:
my plex dns method works on mac os it’s what I made script on
the boot up scripts only work on linux but you can run it manually extract content and run python ./fakedns.py -c ./dns.conf
