Plex app (iOS): how to manage movies?
I’m on holiday on the other side of the world. I can access my movies library for view with the iOS app. But I need to organize them (i.e. change tags, rename, etc.). Is there a way, or another app, to do that? Unfortunately I cannot access the server via web.
Thanks.
Are you referring to just the synced files on your phone? You can’t change those. If you mean that your phone is accessing the server, there’s no reason why PlexWeb won’t work, and you can edit the names and such through that.
Yes, I mean to access the form where to edit the name, description, tag (to assign it to a “folder”) and so. On the Plex app I can’t find this menu.
This is all I’ve access to (sorry for the mess, I’m on my iPad):
Maybe I’ve to watch to some other menu?
You can go to app.Plex.tv on your iPad browser, no?
Oh my bad. :slight_smile:
I was so used to access Plex with IP when I was at home, that I didn’t even know there was a web interface accessible from everywhere. :stuck_out_tongue:
Many thanks @cblevins321 ! :slight_smile:
Protip: The app.plex.tv one is updated more often than the embedded one in the server that you get to by going to the IP address. You’re better off just using the plex.tv one all the time (it connects directly to your server when inside the home network).
