LIke the title states I get this error when I setup Plex Assistant through Home Assistant. Always get the following error. I even went as far as going multiple fresh installs of Home Assistant and still the same error. What could it be on my end causing this issue?
This error originated from a custom integration.
Logger: homeassistant.config_entries
Source: custom_components/plex_assistant/plex_assistant.py:37
Integration: Plex Assistant (documentation)
First occurred: 8:37:45 AM (1 occurrences)
Last logged: 8:37:45 AM
Error setting up entry http://ipaddress:32400 for plex_assistant
Traceback (most recent call last):
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 313, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File “/config/custom_components/plex_assistant/init.py”, line 79, in async_setup_entry
pa = await hass.async_add_executor_job(pa_executor, server, list(start_script.keys()))
File “/usr/local/lib/python3.9/concurrent/futures/thread.py”, line 52, in run
result = self.fn(*self.args, **self.kwargs)
File “/config/custom_components/plex_assistant/init.py”, line 76, in pa_executor
_LOGGER.debug(f"Media titles: {len(_pa.media[‘all_titles’])}")
File “/config/custom_components/plex_assistant/plex_assistant.py”, line 37, in media
media_items[f"{item}_titles"] = [x.title for x in self.library.search(libtype=item, sort=“addedAt:desc”)]
File “/usr/local/lib/python3.9/site-packages/plexapi/library.py”, line 106, in search
return self.fetchItems(key)
File “/usr/local/lib/python3.9/site-packages/plexapi/base.py”, line 260, in fetchItems
data = self._server.query(ekey, params=url_kw)
File “/usr/local/lib/python3.9/site-packages/plexapi/server.py”, line 669, in query
raise BadRequest(message)
plexapi.exceptions.BadRequest: (500) internal_server_error; http://ipaddress:32400/library/all?sort=addedAt%3Adesc&type=10 Internal Server Error
