How does on convert the BeginsAt time to localtime. No matter what I try it converts to 21:00 when it should be 22:00 when using powershell.
Adapted from some Stack Overflow proposals (though I’ve done similar in C#):
# Get DateTime object representing 1/1/1970 at midnight
$epoch = New-Object -Type DateTime 1970, 1, 1, 0, 0, 0, 0
# Add Unix epoch timestamp to the origin time, result is UTC
$timestamp = $epoch.AddSeconds(1744050670)
# Convert timestamp to local time
$timestamp_local = [TimeZone]::CurrentTimeZone.ToLocalTime($timestamp)
# Print result
$timestamp_local
# Just the time as a string, in 24 hour format
$time_string = $timestamp_local.ToString("HH:mm")
This assumes that the beginsAt value you’re pulling is indeed a Unix timestamp (as are most in the Plex databases these days).
[Edit]
Or, most of the above in one step (plus the string conversion):
$beginsAt = Get-Date -UnixTimeSeconds 1744050670
$beginsAtStr = $beginsAt.ToString("HH:mm")
Thanks that works. I spent an hour or more with copilot giving me scripts that always were one hour off.
You’re welcome, glad you got it working!
