Time zone offset
I can’t seem to figure out inside a channel how to find the local Timezone or timezone offset. Can anyone else share how to accomplish converting a Utc time stamp to local time?
I'm pretty sure that the framework method Datetime.FromTimestamp() takes a UTC timestamp and mixes it with local timezone info to return a datetime object.
You can then use python's built-in datetime methods to extract .date(), .time() or other info as necessary and they should all take local timezone into consideration.
I had hoped the same thing, but it seems to preserve the UTC timezone.
Here is the code I have so far ( in the code for now I am assuming a 6 hour offset)
  unixtimestarted = Datetime.TimestampFromDatetime(Datetime.ParseDate(airingData['startTime']))
  timezoneoffset = 6 * 60 * 60
  displayeddate = str(Datetime.FromTimestamp(Datetime.TimestampFromDatetime(Datetime.ParseDate(airingData['startTime'])) -timezoneoffset))
Why are you using Datetime.ParseDate() prior to Datetime.FromTimestamp()?
I wouldn't be surprised if that's throwing a wrench into the timezone handling.
The original date I am getting is a string that looks like 2014-07-16T23:30Z which I would need to convert to a Datetime object first right?
Ah. I was envisioning the wrong type of timestamp.
Try:
startdate = Datetime.ParseDate(airingData['startTime'])
timestarted = startdate.time()
datestarted = startdate.date()
It still does not give a local timestamp:
here is my source data:
'startTime': '2014-07-15T20:00Z'
Here is the output of the code:
2014-07-14 20:02:48,876 (109f07000) :  INFO (__init__:948) - ***TabloTV: startdate: datetime.datetime(2014, 7, 15, 20, 0, tzinfo=tzutc())
2014-07-14 20:02:48,876 (109f07000) :  INFO (__init__:948) - ***TabloTV: time: datetime.time(20, 0)
2014-07-14 20:02:48,876 (109f07000) :  INFO (__init__:948) - ***TabloTV: date: datetime.date(2014, 7, 15)
This should be 3 PM local time
I guess I was wrong about the Framework taking local timezones into account.
Here's a suggestion which _should_ avoid requiring any hard-coded TZ info.
local = Datetime.ParseDate('2014-07-16T23:30Z') - (Datetime.UTCNow() - Datetime.Now())
Not sure here, and haven't tested, but will above work for timezones on both sides on GMT?
/T
And maybe better with :
https://docs.python.org/2/library/datetime.html#tzinfo-objects
tzinfo.fromutc(self, dt)
/T
/T
I think so.
/T
or that.
I think so.
LOL, and good enough for me...
(If it ain't broken...don't fix it)
/T
I'll try those examples later tonight, but I think I have tried basically the same thing. I found part of the issue, Datetime.Now() returns a naive object and has no tzinfo so Datetime.Now and Datetime.UTCnow() both return the same time. Any ideas how to get an Aware Datetime object?
See: https://docs.python.org/2/library/datetime.html
Ok, In case anyone else ever has this issue, This appears to work:
   datetime = Datetime.Now()
    timezoneoffset = int((datetime - datetime.utcnow()).total_seconds())
Thanks for posting your findings.
