Plex broken after migration
Hello all and thank you in advance! Here’s my issue: recently I did a clean Windows installation on my Plex server. I followed the official instructions and transferred over registry keys and the local app data.
Everything seemed fine, except I’m now trying to modify a section that has moved due to hard drives changing and each time I attempt to make a change, I get a “Your changes could not be saved error”. I’ve attempted uninstalling and reinstalling, restoring from a known good database, all to no avail. I wanted to know if anyone here had a better idea of what’s going on. I looked through the log as well and I’m stumped. I’ve included the logs!
Edit: I’ve been looking over some other posts where people have reported similar issues. I saw that many fixed their problems when a proxy was involved, but I don’t have anything of the sort configured. I also noted another case where disabling IPv6 seemed to resolve the issue, did not work here. Also, clearing the com.plexapp.system plugin and allowing the server to recreate it, did not work. I’m attaching logs from the plugin and server. I’m going to keep looking for solutions, but, at least to me, this seems a rather unusual set of circumstances.
com.plexapp.system log
2019-10-28 14:27:16,510 (1b04) : INFO (core:349) - Starting framework core - Version: 2.6.3, Build: 0f4abfb (Thu Oct 17 02:36:14 UTC 2019)
2019-10-28 14:27:16,512 (1b04) : DEBUG (core:361) - Using the elevated policy
2019-10-28 14:27:16,512 (1b04) : DEBUG (core:365) - Extending whitelist: [‘cgi’, ‘tempfile’]
2019-10-28 14:27:16,512 (1b04) : DEBUG (core:450) - Starting runtime component.
2019-10-28 14:27:16,516 (1b04) : DEBUG (core:450) - Starting caching component.
2019-10-28 14:27:16,517 (1b04) : DEBUG (core:450) - Starting data component.
2019-10-28 14:27:16,517 (1b04) : DEBUG (core:450) - Starting networking component.
2019-10-28 14:27:16,519 (1b04) : DEBUG (networking:284) - Loaded HTTP cookies
2019-10-28 14:27:16,549 (1b04) : DEBUG (networking:452) - Setting the default network timeout to 20.0
2019-10-28 14:27:16,551 (1b04) : DEBUG (core:450) - Starting localization component.
2019-10-28 14:27:16,551 (1b04) : INFO (localization:409) - Setting the default locale to en-us
2019-10-28 14:27:16,553 (1b04) : DEBUG (localization:427) - Loaded en strings
2019-10-28 14:27:16,553 (1b04) : DEBUG (core:450) - Starting messaging component.
2019-10-28 14:27:16,555 (1b04) : DEBUG (core:450) - Starting debugging component.
2019-10-28 14:27:16,555 (1b04) : DEBUG (core:450) - Starting services component.
2019-10-28 14:27:16,555 (1b04) : DEBUG (core:450) - Starting myplex component.
2019-10-28 14:27:16,555 (1b04) : DEBUG (core:450) - Starting notifications component.
2019-10-28 14:27:16,783 (1b04) : DEBUG (accessor:68) - Creating a new model access point for provider com.plexapp.system in namespace ‘metadata’
2019-10-28 14:27:16,802 (1154) : DEBUG (services:265) - Plug-in is not daemonized - loading services from system
2019-10-28 14:27:16,802 (1b04) : DEBUG (runtime:1117) - Created a thread named ‘load_all_services’
2019-10-28 14:27:16,806 (1154) : DEBUG (networking:166) - Requesting ‘http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
2019-10-28 14:27:16,808 (1b04) : DEBUG (runtime:1117) - Created a thread named ‘get_server_info’
2019-10-28 14:27:16,809 (1b64) : DEBUG (networking:166) - Requesting ‘http://127.0.0.1:32400
2019-10-28 14:27:16,811 (1b04) : DEBUG (core:150) - Finished starting framework core
2019-10-28 14:27:16,812 (1b04) : DEBUG (core:560) - Loading plug-in code
2019-10-28 14:27:16,836 (1b64) : DEBUG (core:538) - Machine identifier is be168ac139f09179c1ebd26dc18aea0020b980fa
2019-10-28 14:27:16,838 (1b64) : DEBUG (core:539) - Server version is 1.18.1.1973-0f4abfbcc
2019-10-28 14:27:16,868 (1b04) : DEBUG (core:566) - Finished loading plug-in code
2019-10-28 14:27:16,868 (1b04) : DEBUG (runtime:640) - Adding a prefix handler for ‘System’ (‘/system’)
Plex Media Server log
Oct 28, 2019 14:26:57.292 [4108] INFO - Plex Media Server v1.18.1.1973-0f4abfbcc - Microsoft PC x64 - build: windows-x86 windows - GMT -04:00
Oct 28, 2019 14:26:57.292 [4108] INFO - Windows version: 10.0 (Build 14393), language en-US
Oct 28, 2019 14:26:57.292 [4108] INFO - 16 2400 MHz processor(s): Architecture=0, Level=6, Revision=16130 Processor Identifier=Intel64 Family 6 Model 63 Stepping 2, GenuineIntel
Oct 28, 2019 14:26:58.823 [6544] INFO - OCSP: Successfully retrieved response from cache.
Oct 28, 2019 14:26:59.307 [4396] WARN - Crash: Crash reporting disabled
Oct 28, 2019 14:27:00.901 [6724] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 14:27:00.901 [6724] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 14:27:02.088 [5696] ERROR - Failed to begin transaction (…\Library\MetadataCollection.cpp:174) (tries=1): Cannot begin transaction. database is locked
Oct 28, 2019 14:27:02.432 [5696] ERROR - Failed to begin transaction (…\Library\MetadataCollection.cpp:174) (tries=2): Cannot begin transaction. database is locked
Oct 28, 2019 14:27:02.760 [2344] WARN - [Preferences] No update channels loaded, so showing the previously-selected channel, labelled ‘unknown’ since we don’t really know the name.
Oct 28, 2019 14:27:02.917 [6724] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 14:27:02.917 [6724] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 14:27:03.135 [5696] ERROR - Failed to begin transaction (…\Library\MetadataCollection.cpp:174) (tries=3): Cannot begin transaction. database is locked
Oct 28, 2019 14:27:03.292 [2344] INFO - AutoUpdate: no updates available
Oct 28, 2019 14:27:03.526 [5696] ERROR - Failed to begin transaction (…\Library\MetadataCollection.cpp:174) (tries=4): Cannot begin transaction. database is locked
Oct 28, 2019 14:27:03.557 [3828] WARN - Sync: sync list 13999786 belonging to user 1617207 (NB-Media-Plex) has died of old age, ignoring
Oct 28, 2019 14:27:03.557 [3828] INFO - Sync: downloaded 1 sync list(s) with 0 sync items(s): 0 new, 0 updated, 0 deleted
Oct 28, 2019 14:27:04.323 [5696] ERROR - Failed to begin transaction (…\Library\MetadataCollection.cpp:174) (tries=5): Cannot begin transaction. database is locked
Oct 28, 2019 14:27:04.432 [2344] WARN - QueryParser: Invalid field ‘libraryHubsOnly’ found, ignoring.
Oct 28, 2019 14:27:04.448 [2344] WARN - QueryParser: Invalid field ‘libraryHubsOnly’ found, ignoring.
Oct 28, 2019 14:27:04.463 [2344] WARN - QueryParser: Invalid field ‘libraryHubsOnly’ found, ignoring.
Oct 28, 2019 14:27:04.917 [5696] ERROR - Failed to begin transaction (…\Library\MetadataCollection.cpp:174) (tries=6): Cannot begin transaction. database is locked
Oct 28, 2019 14:27:04.948 [6428] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 14:27:04.948 [6428] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 14:27:04.963 [5216] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.fanarttv], we’re killing it.
Oct 28, 2019 14:27:04.963 [7068] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.lastfm], we’re killing it.
Oct 28, 2019 14:27:04.963 [1596] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.htbackdrops], we’re killing it.
Oct 28, 2019 14:27:04.963 [1596] ERROR - Error received reading configuration for com.plexapp.agents.htbackdrops
Oct 28, 2019 14:27:04.963 [5216] ERROR - Error received reading configuration for com.plexapp.agents.fanarttv
Oct 28, 2019 14:27:04.963 [7068] ERROR - Error received reading configuration for com.plexapp.agents.lastfm
Oct 28, 2019 14:27:06.104 [5696] ERROR - Failed to begin transaction (…\Library\MetadataCollection.cpp:174) (tries=7): Cannot begin transaction. database is locked
Oct 28, 2019 14:27:06.463 [5696] ERROR - Failed to begin transaction (…\Library\MetadataCollection.cpp:174) (tries=8): Cannot begin transaction. database is locked
Oct 28, 2019 14:27:06.963 [6148] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 14:27:06.963 [6148] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 14:27:06.979 [7068] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.lyricfind], we’re killing it.
Oct 28, 2019 14:27:06.979 [7068] ERROR - Error received reading configuration for com.plexapp.agents.lyricfind
Oct 28, 2019 14:27:06.995 [1596] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.movieposterdb], we’re killing it.
Oct 28, 2019 14:27:06.995 [5216] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.localmedia], we’re killing it.
Oct 28, 2019 14:27:06.995 [5216] ERROR - Error received reading configuration for com.plexapp.agents.localmedia
Oct 28, 2019 14:27:06.995 [1596] ERROR - Error received reading configuration for com.plexapp.agents.movieposterdb
Oct 28, 2019 14:27:07.198 [5696] ERROR - Failed to begin transaction (…\Library\MetadataCollection.cpp:174) (tries=9): Cannot begin transaction. database is locked
Oct 28, 2019 14:27:07.682 [5696] ERROR - Failed to begin transaction (…\Library\MetadataCollection.cpp:174) (tries=10): Cannot begin transaction. database is locked
Oct 28, 2019 14:27:07.682 [5696] ERROR - Fixup class DatabaseFixupsSyncCollections threw an exception: Cannot begin transaction. database is locked
Oct 28, 2019 14:27:08.979 [6928] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 14:27:08.979 [6928] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 14:27:08.995 [7068] ERROR - Timeout or error reading status line from plug-in pipe [org.musicbrainz.agents.music], we’re killing it.
Oct 28, 2019 14:27:08.995 [7068] ERROR - Error received reading configuration for org.musicbrainz.agents.music
Oct 28, 2019 14:27:09.010 [1596] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.none], we’re killing it.
Oct 28, 2019 14:27:09.010 [5216] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.opensubtitles], we’re killing it.
Oct 28, 2019 14:27:09.010 [5216] ERROR - Error received reading configuration for com.plexapp.agents.opensubtitles
Oct 28, 2019 14:27:09.010 [1596] ERROR - Error received reading configuration for com.plexapp.agents.none
Oct 28, 2019 14:27:10.995 [5996] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 14:27:10.995 [5996] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 14:27:11.010 [7068] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.imdb], we’re killing it.
Oct 28, 2019 14:27:11.010 [7068] ERROR - Error received reading configuration for com.plexapp.agents.imdb
Oct 28, 2019 14:27:11.026 [5216] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.plexthememusic], we’re killing it.
Oct 28, 2019 14:27:11.026 [1596] ERROR - Timeout or error reading status line from plug-in pipe [tv.plex.agents.music], we’re killing it.
Oct 28, 2019 14:27:11.026 [5216] ERROR - Error received reading configuration for com.plexapp.agents.plexthememusic
Oct 28, 2019 14:27:11.026 [1596] ERROR - Error received reading configuration for tv.plex.agents.music
Oct 28, 2019 14:27:13.010 [6136] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 14:27:13.010 [6136] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 14:27:13.026 [7068] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.themoviedb], we’re killing it.
Oct 28, 2019 14:27:13.026 [7068] ERROR - Error received reading configuration for com.plexapp.agents.themoviedb
Oct 28, 2019 14:27:13.042 [5216] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.thetvdb], we’re killing it.
Oct 28, 2019 14:27:13.042 [5216] ERROR - Error received reading configuration for com.plexapp.agents.thetvdb
Oct 28, 2019 14:27:13.057 [1596] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.abstvdb], we’re killing it.
Oct 28, 2019 14:27:13.057 [1596] ERROR - Error received reading configuration for com.plexapp.agents.abstvdb
Oct 28, 2019 14:27:13.057 [6724] INFO - Refreshing paths watched by LibraryUpdateManager
Oct 28, 2019 14:27:14.370 [5996] ERROR - Errors in PUT request: Bad Request
400 Bad Request
‘agent’ is missing or invalid
Oct 28, 2019 14:27:15.026 [4120] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 14:27:15.026 [4120] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 14:27:15.057 [4380] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.thetvdb], we’re killing it.
Oct 28, 2019 14:27:15.057 [4380] ERROR - Error received reading configuration for com.plexapp.agents.thetvdb
Oct 28, 2019 14:27:15.073 [0220] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.imdb], we’re killing it.
Oct 28, 2019 14:27:15.073 [0220] ERROR - Error received reading configuration for com.plexapp.agents.imdb
Oct 28, 2019 14:27:15.073 [0220] ERROR - PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 28, 2019 14:27:15.073 [0220] ERROR - IVA: failed to get IMDB prefs
Oct 28, 2019 14:27:17.042 [5808] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 14:27:17.042 [5808] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 14:27:17.807 [6428] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 14:27:17.807 [6428] ERROR - Error received reading configuration for com.plexapp.system
Server Version#: 1.18.1.1973-0f4abfbcc-x86
When you restored the local appdata, did you check the permissions to make sure they are correct for the new install?
The local app data is stored on a separate hard drive and was not touched during the new installation of windows. I’d like to be sure and confirm though, how could I do that on a windows machine?
First, make sure it’s looking in the right spot. In Plex Web, look under the General Tab for your server settings. Find the value for “The path where local application data is stored”. Make sure that points to the “Plex Media Server” folder.
To check permissions, open file explorer and get to the same folder as above. Right click on the Plex Media Server folder and select properties, then go to the security tab. Make sure your current Windows user has access.
I can’t access the sever settings from the UI, I get an error, but I’ve checked the registry entries and they correctly correspond with the location of the “Plex Media Server”.
I checked permissions and made sure that both the “Administrators” group and my user had full permissions. I’m also unable, as mentioned before, to edit server settings or libraries. However, my content still plays.
After, I relaunched and the following log is what I got back:
Plex Media Server Log
Oct 28, 2019 17:37:57.260 [7124] INFO - Plex Media Server v1.18.1.1973-0f4abfbcc - Microsoft PC x64 - build: windows-x86 windows - GMT -04:00
Oct 28, 2019 17:37:57.260 [7124] INFO - Windows version: 10.0 (Build 14393), language en-US
Oct 28, 2019 17:37:57.260 [7124] INFO - 16 2400 MHz processor(s): Architecture=0, Level=6, Revision=16130 Processor Identifier=Intel64 Family 6 Model 63 Stepping 2, GenuineIntel
Oct 28, 2019 17:37:58.713 [7056] INFO - OCSP: Successfully retrieved response from cache.
Oct 28, 2019 17:37:59.275 [6844] WARN - Crash: Crash reporting disabled
Oct 28, 2019 17:38:00.822 [6444] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:00.822 [6444] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:02.025 [6504] WARN - Held transaction for too long (…\Library\MetadataCollection.cpp:237): 0.109375 seconds
Oct 28, 2019 17:38:02.838 [6444] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:02.838 [6444] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:03.525 [5708] WARN - Sync: sync list 13999786 belonging to user 1617207 (NB-Media-Plex) has died of old age, ignoring
Oct 28, 2019 17:38:03.525 [5708] INFO - Sync: downloaded 1 sync list(s) with 0 sync items(s): 0 new, 0 updated, 0 deleted
Oct 28, 2019 17:38:03.838 [6492] INFO - AutoUpdate: no updates available
Oct 28, 2019 17:38:04.853 [4336] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:04.853 [4336] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:04.869 [3120] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.lastfm], we’re killing it.
Oct 28, 2019 17:38:04.869 [1780] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.fanarttv], we’re killing it.
Oct 28, 2019 17:38:04.869 [0732] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.htbackdrops], we’re killing it.
Oct 28, 2019 17:38:04.869 [3120] ERROR - Error received reading configuration for com.plexapp.agents.lastfm
Oct 28, 2019 17:38:04.869 [0732] ERROR - Error received reading configuration for com.plexapp.agents.htbackdrops
Oct 28, 2019 17:38:04.869 [1780] ERROR - Error received reading configuration for com.plexapp.agents.fanarttv
Oct 28, 2019 17:38:04.978 [5760] WARN - QueryParser: Invalid field ‘libraryHubsOnly’ found, ignoring.
Oct 28, 2019 17:38:04.994 [5760] WARN - QueryParser: Invalid field ‘libraryHubsOnly’ found, ignoring.
Oct 28, 2019 17:38:05.010 [5760] WARN - QueryParser: Invalid field ‘libraryHubsOnly’ found, ignoring.
Oct 28, 2019 17:38:05.025 [5760] WARN - QueryParser: Invalid field ‘libraryHubsOnly’ found, ignoring.
Oct 28, 2019 17:38:05.041 [5760] WARN - QueryParser: Invalid field ‘libraryHubsOnly’ found, ignoring.
Oct 28, 2019 17:38:06.869 [0288] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:06.869 [0288] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:06.885 [1780] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.lyricfind], we’re killing it.
Oct 28, 2019 17:38:06.885 [1780] ERROR - Error received reading configuration for com.plexapp.agents.lyricfind
Oct 28, 2019 17:38:06.900 [0732] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.movieposterdb], we’re killing it.
Oct 28, 2019 17:38:06.900 [3120] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.localmedia], we’re killing it.
Oct 28, 2019 17:38:06.900 [3120] ERROR - Error received reading configuration for com.plexapp.agents.localmedia
Oct 28, 2019 17:38:06.900 [0732] ERROR - Error received reading configuration for com.plexapp.agents.movieposterdb
Oct 28, 2019 17:38:08.885 [4492] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:08.885 [4492] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:08.900 [1780] ERROR - Timeout or error reading status line from plug-in pipe [org.musicbrainz.agents.music], we’re killing it.
Oct 28, 2019 17:38:08.900 [1780] ERROR - Error received reading configuration for org.musicbrainz.agents.music
Oct 28, 2019 17:38:08.916 [3120] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.opensubtitles], we’re killing it.
Oct 28, 2019 17:38:08.916 [0732] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.none], we’re killing it.
Oct 28, 2019 17:38:08.916 [3120] ERROR - Error received reading configuration for com.plexapp.agents.opensubtitles
Oct 28, 2019 17:38:08.916 [0732] ERROR - Error received reading configuration for com.plexapp.agents.none
Oct 28, 2019 17:38:10.900 [4468] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:10.900 [4468] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:10.916 [1780] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.imdb], we’re killing it.
Oct 28, 2019 17:38:10.916 [1780] ERROR - Error received reading configuration for com.plexapp.agents.imdb
Oct 28, 2019 17:38:10.931 [3120] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.plexthememusic], we’re killing it.
Oct 28, 2019 17:38:10.931 [3120] ERROR - Error received reading configuration for com.plexapp.agents.plexthememusic
Oct 28, 2019 17:38:10.947 [0732] ERROR - Timeout or error reading status line from plug-in pipe [tv.plex.agents.music], we’re killing it.
Oct 28, 2019 17:38:10.947 [0732] ERROR - Error received reading configuration for tv.plex.agents.music
Oct 28, 2019 17:38:12.916 [3556] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:12.916 [3556] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:12.931 [1780] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.themoviedb], we’re killing it.
Oct 28, 2019 17:38:12.931 [1780] ERROR - Error received reading configuration for com.plexapp.agents.themoviedb
Oct 28, 2019 17:38:12.947 [3120] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.thetvdb], we’re killing it.
Oct 28, 2019 17:38:12.947 [3120] ERROR - Error received reading configuration for com.plexapp.agents.thetvdb
Oct 28, 2019 17:38:12.963 [0732] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.abstvdb], we’re killing it.
Oct 28, 2019 17:38:12.963 [0732] ERROR - Error received reading configuration for com.plexapp.agents.abstvdb
Oct 28, 2019 17:38:12.963 [6444] INFO - Refreshing paths watched by LibraryUpdateManager
Oct 28, 2019 17:38:14.931 [4440] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:14.931 [4440] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:14.994 [3188] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.imdb], we’re killing it.
Oct 28, 2019 17:38:14.994 [3188] ERROR - Error received reading configuration for com.plexapp.agents.imdb
Oct 28, 2019 17:38:14.994 [3188] ERROR - PlexClient::downloadContainer: expected MediaContainer element, found html
Oct 28, 2019 17:38:14.994 [3188] ERROR - IVA: failed to get IMDB prefs
Oct 28, 2019 17:38:16.947 [2072] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:16.947 [2072] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:18.963 [4728] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:18.963 [4728] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:20.400 [4440] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.thetvdb], we’re killing it.
Oct 28, 2019 17:38:20.400 [4440] ERROR - Error received reading configuration for com.plexapp.agents.thetvdb
Oct 28, 2019 17:38:20.980 [4156] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:20.980 [4156] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:22.996 [4468] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:22.996 [4468] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:23.683 [0288] ERROR - Errors in PUT request: Bad Request
400 Bad Request
Oct 28, 2019 17:38:24.605 [0288] ERROR - Errors in PUT request: Bad Request
400 Bad Request
Oct 28, 2019 17:38:25.012 [6492] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:25.012 [6492] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:27.027 [4496] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:27.027 [4496] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:29.043 [5052] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:29.043 [5052] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:31.058 [6484] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:31.058 [6484] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:33.074 [4336] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:33.074 [4336] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:35.090 [2088] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:35.090 [2088] ERROR - Error received reading configuration for com.plexapp.system
Oct 28, 2019 17:38:37.103 [6220] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.system], we’re killing it.
Oct 28, 2019 17:38:37.103 [6220] ERROR - Error received reading configuration for com.plexapp.system
If you can play content but can’t access setting, that could mean you are signed in under a shared user account and not your main Plex user account.
If you want to provide logs, please turn on debug logging and post the entire file, do not cut and paste.
Nope, signed in as my primary user whose owns the server. None of the logs are cut and pastes, they are all complete and with debugging turned on. I’ve included additional logs below. All I did during the logs below is: start the server, attempt to play and “invalid” item, and attempt to change the library location.
By the way, thank you for taking the time to look at this stuff with me and attempting to find a solution!
[edit - mod removed]
I had similar problem. The only way it was to copy the preferences.xlm, erase uninstall and erase plex installation. Doing a clean installation, it started to work. But, I had to rebuild all the libraries and dvr.
I’m starting to think that might be the only solution and if I have to rebuild everything, I’ll probably switch to Emby. I’ve been encountering lots of bugs lately.
I know what you mean. But, in my case, I won’t update again until I know that it is safe. When plex works, it does really good.
By cut and paste, I meant don’t paste the text into your comment. Include the log file as an attachment.
Ah.
Plex Media Server.log (818 Bytes) com.plexapp.system.log (2.8 KB)
There’s very little in that log file. Did you try to recreate the problem you were having before grabbing the log? Please try again and just zip up the entire log folder.
Yes. In all the logs I’ve started the server and replicated the error I’m having. Here’s a link to the zip of the entire log folder. Thanks!
Google Drive Link
Are you sure that’s the log folder? I haven’t downloaded it yet, it’s 2GB in size. That doesn’t look right. To be clear, it should only be the log folder, not the entire “Plex Media Server” folder.
It’s only the log folder. My entire Plex Media server folder is a few hundred gigabytes. There’s a few DLNA logs that are ~400mbs. Not sure why.
And you compressed the files, not just stored them? A zipped log file should not be anywhere near 2 GB. Try grabbing the logs using Plex Web instead. Settings \ Troubleshoot \ Download logs. That will create a zip of what I want.
Yes, that’s with compression and I can’t access any server settings. Just get an error. Here’s another upload without those giant DLNA logs. I don’t use the DLNA services anywhere, so I’m not sure why they’re so large.
New Drive Upload
Those logs are from 2014. Are you sure you are looking at the right folder? Your earlier logs from yesterday had the right date.
You’re right. I wasn’t. Not sure why but there was a series of left over log files from a 2014 installation. Sorry about that and thank you for bearing with me. Here’s the recent folder:
Correct Logs, I promise
