PLEX bundling movies Synology
After the latest upgrade I noticed that if I have a series of movies (Insert Movie Franchise here) I used to have say, all of the movies in order. Now, for instances I have a 3 movie franchise that shows 1-3 but then it created a fourth movie box, which shows all 3 movies inside of it. It’s fairly redundant and my screen looks horrible with all of the crappy artwork and stuff. Any thoughts would be awesome
It sounds like you are referring to Collections. If I’m correct, search the forum for “Collections” to learn more.
Thanks sGarver. Will do.
@trumpy81 Thank you! Found that yesterday and it fixed half of my problem. On iOStv now it’s a complete disaster. Showing collections and then movies. I’m searching around for that now. Thank you again for that!
@trumpy81 Well, after trying a whole bunch of things, I uninstalled PlexMediaServer-1.11.3.4803-c40bba82e-x86.spk. It was a tragedy to look at. I downgraded to the last known good package I had, PlexMediaServer-1.10.0.4523-648bc61d4-x86.spk, and things look great again. I’ll try and follow the forums for this. Thank you.
