Plex cannot find my Hauppauge WinTV-quadHD (PCIe model) tv tuner on Ubuntu 18.04
I just did a fresh install of Ubuntu 18.04 and installed Plex but Plex cannot find my Hauppauge WinTV-quadHD (PCIe model) tv tuner. Anyone with any clues? It used to work on my old install… I’ve followed the instructions I used last time I reloaded Ubuntu/Plex, and even went as far as to pull the latest instructions from GIT, but no luck.
Below is a snip from my Plex Logs, but first I think the problem is a permissions issue:
Jun 10, 2020 15:12:09.207 [0x7fe9d324c740] DEBUG - Unable to open named mutex F8EEB26D-AB23-4061-8250-130AB5285A4A with option 2: Permission denied
Jun 10, 2020 15:12:09.194 [0x7fe9ce37d700] INFO - Plex Tuner Service v1.0.0.0 - Ubuntu snap x86_64 - build:
Jun 10, 2020 15:12:09.194 [0x7fe9ce37d700] INFO - Linux version: 5.3.0-56202005281620-generic (#0+mediatree+hauppauge~hwe-Ubuntu SMP Fri May 29 18:32:07 UTC 20), language: C
Jun 10, 2020 15:12:09.194 [0x7fe9ce37d700] INFO - Processor Intel® Core™ i5-3470 CPU @ 3.20GHz
Jun 10, 2020 15:12:09.194 [0x7fe9ce37d700] INFO - /snap/plexmediaserver/98/Plex Tuner Service /snap/plexmediaserver/98/Resources/Tuner/Private /snap/plexmediaserver/98/Resources/Tuner/Shared 1.19.4.2902-69560ce1e 32600 /waitmutex
Jun 10, 2020 15:12:08.997 [0x7fe9d324c740] INFO - [I] broker_t::start…
Jun 10, 2020 15:12:09.136 [0x7fe9d324c740] INFO - [I] device_manager_t::init.
Jun 10, 2020 15:12:09.136 [0x7fe9d324c740] INFO - [I] device_manager_t::init. Initialize provider manager
Jun 10, 2020 15:12:09.136 [0x7fe9d324c740] INFO - [I] device_manager_t::init. Initialize all device auxes
Jun 10, 2020 15:12:09.136 [0x7fe9d324c740] INFO - [I] dvb_device_factory_t::get_aux_list
Jun 10, 2020 15:12:09.140 [0x7fe9d324c740] INFO - [I] tvbutler_aux_t::init
Jun 10, 2020 15:12:09.141 [0x7fe9d324c740] INFO - [I] web_server_t::start. Starting web server on port 32600
Jun 10, 2020 15:12:14.547 [0x7fe9cd37b700] INFO - [I] web_service_t::process_device_discovery
Jun 10, 2020 15:12:14.547 [0x7fe9cd37b700] INFO - [I] device_reactor_t::get_device_list ()
Jun 10, 2020 15:12:14.547 [0x7fe9cd37b700] INFO - [I] dvb_device_factory_t::get_device_list ()
Jun 10, 2020 15:12:16.549 [0x7fe9cd37b700] INFO - [I] SAT2IP - discover_satip_servers(): no servers found
Jun 10, 2020 15:12:16.967 [0x7fe9cd37b700] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jun 10, 2020 15:12:16.967 [0x7fe9cd37b700] WARN - [E] v4l::DeviceGetList_impl. open failed on frontend /dev/dvb/adapter0/frontend0 (1)
Jun 10, 2020 15:12:16.967 [0x7fe9cd37b700] WARN - [E] v4l::DeviceGetList_impl. open failed on frontend /dev/dvb/adapter1/frontend0 (1)
Jun 10, 2020 15:12:16.968 [0x7fe9cd37b700] WARN - [E] v4l::DeviceGetList_impl. open failed on frontend /dev/dvb/adapter2/frontend0 (1)
Jun 10, 2020 15:12:16.968 [0x7fe9cd37b700] WARN - [E] v4l::DeviceGetList_impl. open failed on frontend /dev/dvb/adapter3/frontend0 (1)
Jun 10, 2020 15:12:16.971 [0x7fe9cd37b700] INFO - [I] onetv_factory::DeviceGetListEx >>
Jun 10, 2020 15:12:16.971 [0x7fe9cd37b700] WARN - [W] onetv_factory::DeviceGetListEx. libusb_init returned an error -99
Reload of OS and Plex seems to have fixed this problem.
