Server Version#: 1.19.3.2852-219a9974e amd64 [installed,local]
Tuner Make/Model: Hauppauge model 165100, rev B4I6
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Installing new version of config file /etc/apt/sources.list.d/plexmediaserver.list …
PlexMediaServer install: PlexMediaServer-1.19.3.2852-219a9974e - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Installation Type: New
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: render
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /tmp
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Transcoding HW: Found <<-- doesn’t this imply Plex sees the tuner?
PlexMediaServer install: Completing final configuration.
Created symlink /etc/systemd/system/multi-user.target.wants/plexmediaserver.service → /lib/systemd/system/plexmediaserver.service.
PlexMediaServer install: PlexMediaServer-1.19.3.2852-219a9974e - Installation successful. Errors: 0, Warnings: 0
Processing triggers for libc-bin (2.31-0ubuntu9) …
Processing triggers for mime-support (3.64ubuntu1) …
May 25, 2020 13:07:43.750 [0x7fc05cf7d700] INFO - [I] SAT2IP - discover_satip_servers(): no servers found
May 25, 2020 13:07:44.174 [0x7fc05cf7d700] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
May 25, 2020 13:07:44.174 [0x7fc05cf7d700] WARN - [E] v4l::DeviceGetList_impl. open failed on frontend /dev/dvb/adapter0/frontend0 (13)
May 25, 2020 13:07:44.174 [0x7fc05cf7d700] WARN - [E] v4l::DeviceGetList_impl. open failed on frontend /dev/dvb/adapter1/frontend0 (13)
May 25, 2020 13:07:44.174 [0x7fc05cf7d700] WARN - [E] v4l::DeviceGetList_impl. open failed on frontend /dev/dvb/adapter2/frontend0 (13)
May 25, 2020 13:07:44.175 [0x7fc05cf7d700] WARN - [E] v4l::DeviceGetList_impl. open failed on frontend /dev/dvb/adapter3/frontend0 (13)
May 25, 2020 13:07:44.179 [0x7fc05cf7d700] INFO - [I] onetv_factory::DeviceGetListEx >>
May 25, 2020 13:07:44.179 [0x7fc05cf7d700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 2352:25925
May 25, 2020 13:07:44.179 [0x7fc05cf7d700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 5451:91
May 25, 2020 13:07:44.179 [0x7fc05cf7d700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:2
May 25, 2020 13:07:44.179 [0x7fc05cf7d700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 5118:25344
May 25, 2020 13:07:44.179 [0x7fc05cf7d700] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:3
May 25, 2020 13:07:46.228 [0x7fc05b77a700] INFO - [I] web_service_t::process_device_discovery
nuplex:~# apt list | grep ^plex
plexmediaserver/now 1.19.3.2852-219a9974e amd64 [installed,local]
dmesg shows the following
[ 11.333642] tveeprom: Hauppauge model 165100, rev B4I6, serial# 4036150387
[ 11.333643] tveeprom: MAC address is 00:0d:fe:92:c4:73
[ 11.333643] tveeprom: tuner model is SiLabs Si2157 (idx 186, type 4)
[ 11.333644] tveeprom: TV standards NTSC(M) ATSC/DVB Digital (eeprom 0x88)
[ 11.333644] tveeprom: audio processor is CX23888 (idx 40)
[ 11.333645] tveeprom: decoder processor is CX23888 (idx 34)
[ 11.333645] tveeprom: has no radio, has IR receiver, has no IR transmitter
[ 11.333646] cx23885: cx23885[0]: hauppauge eeprom: model=165100
[ 11.341652] cx25840 9-0044: cx23888 A/V decoder found @ 0x88 (cx23885[0])
[ 11.972962] cx25840 9-0044: loaded v4l-cx23885-avcore-01.fw firmware (16382 bytes)
[ 12.005644] cx23885: cx23885_dvb_register() allocating 1 frontend(s)
[ 12.005645] cx23885: cx23885[0]: cx23885 based dvb card
[ 12.005646] cx23885: dvb_register(): board=57 port=1
[ 12.022627] si2157 8-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
[ 12.022635] dvbdev: DVB: registering new adapter (cx23885[0])
root@nuplex:~# apt-get install linux-firmware-hauppauge
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 7,350 kB of archives.
After this operation, 7,394 kB of additional disk space will be used.
Get:1 /kernel+mediatree+hauppauge/ubuntu focal/main amd64 linux-firmware-hauppauge all 0.1.6+focal [7,350 kB]
Fetched 7,350 kB in 2s (3,525 kB/s)
Selecting previously unselected package linux-firmware-hauppauge.
(Reading database … 70780 files and directories currently installed.)
Preparing to unpack …/linux-firmware-hauppauge_0.1.6+focal_all.deb …
Unpacking linux-firmware-hauppauge (0.1.6+focal) …
Setting up linux-firmware-hauppauge (0.1.6+focal) … <<–We know we have the right firmware because it’s for this distro
