Hello everyone.
I recently set-up a new Plex Server after moving from a temporary MacBook driven server.
I installed the Windows Server software and started adding files when it came to my attention that even though my language is set as German, my category names such as “Continue Watching” or “Recently Added” were in English and not “Weiter ansehen” or “Zuletzt hinzugefügt” like it was when before when I used the MacOS Server.
In the picture I provide you with I used the sorting feature to showcase the issue. As you can see there are multiple German words like “Alle” or “Staffeln”, however when I open the “sort” menu I can not select “Titel”, “Jahr”, “Erscheinungsdatum” - instead every point of the menu is in English and I would like to revert back to German as it has been prior moving to Windows.
I appreciate any type of help and hope to fix this issue with you together.
Thanks.
