Plex Cloud - where does transcoding happen?
I was wondering if I set up Plex Cloud, then where does the actual transcoding occur?
I have a Plex server both at home and at my seedbox, but I can’t seem to figure out if they’re actually doing the processing.
For Plex Cloud nothing local does any processing at all. That is the entire server and all processing/support for it reside in the cloud.
As far as I know is transcoding made on plex Server itself.
Which, for Plex cloud is located in the cloud. No local server needed.
Yes, Sir.
Direct stream
Cloud (OneDrive,google) -> to your home
Transcoded
Cloud (OneDrive,google) -> Plex sever -> to your home
This is what I read so far…
In the Plex Cloud service, Plex is using the Microsoft Azure Cloud for its back-end PMS/transcoding. This is transparent to the user.
You can try it frist
So how does this impact the users I have on my pc ? This will free up my pc from being used , correct?
Yes. It is completely separate from your local computer.
Yes it will free up your PC from being used if you no longer share your local server
Is there a way to user your local library and transcoding made with Microsoft Azure Cloud, i own a computer not so fast?
No. There is currently no way to ‘outsource’ just the transcoding.
Thank you
