Plex connect Apple TV
Hi all,
I’ve been using Plex for around a year now with PMS on a Windows unit and Plex app on iPhone and iPad in the house.
Yesterday I bought the Apple TV and figured I could try the Plexconnect solution.
Sadly, I have reached the limits of technical ability in trying to set the unit and PC. I’m struggling with the verbiage to be honest around a Certificate error in the python window.
Is there a laymans guide to help me through the steps (I tried the langri.sh site and that’s where I had my epic fail).
Or should I be taking the ATV back and getting something smiler to set up like the Roku?
Yours dumbest,
James
Hi all,
I've been using Plex for around a year now with PMS on a Windows unit and Plex app on iPhone and iPad in the house.
Sadly, I have reached the limits of technical ability in trying to set the unit and PC. I'm struggling with the verbiage to be honest around a Certificate error in the python window.
Is there a laymans guide to help me through the steps (I tried the langri.sh site and that's where I had my epic fail).
Yours dumbest,
James
Plexconnect is very nice.  However, it requires a bit of patience and tenacity not only to setup, but to keep running (meaning the obvious fear that Apple could kill it).  To that end, I suggest a Roku for the easiest out of the box, worry free experience.  I'm not the biggest fan of Roku's Plex interface, but it certainly does the job.
...we might be able to help when knowing that confusing verbiage.
Hi baa,
Great code work, just wish I was as technically adept.
I’m assuming you either need the text that is displayed in the Python window or some sort of log export to be able to help me any further?
I used to program PLCs so in theory I should be better at this :slight_smile: Too many years in project management!
James
Is this the correct information?
09:23:27 PlexConnect: ***
09:23:27 PlexConnect: started: 09:23:27
09:23:27 PlexConnect: IP_self: 192.168.0.2
09:23:27 DNSServer: started: 09:23:27
09:23:27 DNSServer: ***
09:23:27 DNSServer: DNSServer: Serving DNS on port 53.
09:23:27 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.
168.0.2
09:23:27 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld
.apple.com.edgesuite.net'] => 127.0.0.1
09:23:27 DNSServer: forward other to higher level DNS: 8.8.8.8
09:23:28 WebServer: started: 09:23:28
09:23:28 WebServer: ***
09:23:28 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
09:23:28 PlexGDM: ***
09:23:28 PlexGDM: looking up Plex Media Server
09:23:28 WebServer: Failed to access certificate: C: railers.pem
09:23:29 PlexGDM: servers discovered: 1
09:23:29 XMLConverter: PlexGDM - PMS: 192.168.0.2:32400
09:27:54 DNSServer: DNS request received!
09:27:54 DNSServer: Source: ('192.168.0.22', 58088)
09:27:54 DNSServer: Domain: 42.courier-push-apple.com.akadns.net
09:27:54 DNSServer: ***forward request
09:27:54 DNSServer: -> DNS response from higher level
The ATV is running firmware 5.3 if it makes any difference, should I be upgrading this first?
No aTV update necessary...
The certificate is not where is should be... according to you settings.cfg file.
Is that the certificates txt file? If so, it is definitely in the C:/ folder?
Do I need to move the file?
So sorry for the dumb questions. I’ve read similar threads on this forum and just don’t seem to be able to make sense of some of this.
Here’s betting a pint of beer that it’s a 2 second fix. It normally is with me :slight_smile:
Did you create a trailers.pem file following the the installation instructions? That has to be in the certificates folder.
WIKI -> Install guides -> section "Attention!" [https://github.com/iBaa/PlexConnect/wiki/Install-guides]
Though I recommend in reading the other sections as well...
The fix takes longer than 2 sec. "pint of beer" goes [http://forums.plexapp.com/index.php/topic/80675-donations-donations/].
The instructions in the langri.sh website? No, not yet.
Ok last question for clarity. Do I have to create the PEM file using the iPhone configuration utility, etc? If so will try working through all the steps tomorrow evening.
Wish me luck!
Ps can I screw the ATV or PC up by doing these certificate steps?
In short...
- create a certificate using openSSL.
- install it on your aTV using iPhone Utility
It needs a while... follow the instructions.
No, it won't hurt aTV or PC.
Thanks Baa. Totally appreciate your patience.
Will report back with mission result.
Result! Beer coming your way.
Thank you for helping the unhelpable!
Feel free to use me as an example.
Anyone else out there who is technically challenged, just take the steps very slowly and it can be done!
So I have Plexconnect working on an ATV3.  The issues I am having is that nothing ever shows up under Library.  I can use all the channels, the settings all work, and my Plex Media Server is also listed.  I can even search for information and have matching items on my media server show up, but never get anything under Library.  Just "accessing trailers" forever.  Anyone run into this particular problem before?  Plex media server and plexconnect are running on a Mac mini.  Using the Plex app on iPad or Plex Desktop on a computer has no issues accessing and getting information from my media server.
Please start a new thread with the information requested in the "read before posting" sticky and we will help you get it working.
