Plex Connect on OSX Mavericks
Hey all,
Is Plex Connect compatible with Mavericks? I can't seem to get it setup on 10.9.
Hey all,
Yes I have it running on Mavericks the setup was exactly the same as on Mountain Lion just follow the wiki on how to install on OSX
 https://github.com/iBaa/PlexConnect/wiki/Install-guides
In order to help we really need some very specific information; this information is detailed in the 'how to report an issue' link in the 'Please read before posting' thread.
The direct link is:  https://github.com/iBaa/PlexConnect/wiki/How-to-report-an-issue
You might also want to check with version of Python is installed and report that as well
I don't think that we can handle any support for PlexConnect on OSX 10.9. Not now... :-D
I am running PlexConnect on 10.9 DP2 without any problems.
I have it working on the GM, however, I cannot get the auto start "automater" script to work that I copied from the forum. Anyone else having trouble?
Whats the best way to auto start plexconnect?
working here on GM as well, but buffering a lot with MKV files. Does anyone know if there is a settings file I can play with. I can live with less quality if football games would run smooth. thx!
