Plex connect stops working, need to reset network every time
Hello there!
I use my Macbook Air 2013 as Plex Server.
Pretty often when i start up my apple tv and click on trailers it just says connecting to trailers... (when my laptop is on)
Also when this problem occur, I can't connect to Apples Movies, it says the same thing.
So when it does i always go in to the network  on the apple tv3 and put dns on automatic then back to 10.0.0.2 as usual, and it works.
Does anyone else got this problem?
It would help to know exactly what you are doing to get the issue, eg what section and sub section are you pressing on.
Also the info requested in the “read before posting” is usually needed to help diagnose an issue.
