Trailers not available/Terminal Connection?
I'm running Plex on my Mac Mini and went through the setup with my DNS. I'm new to Terminal but here is what happens when I went to connect...
PlexConnect : ***
PlexConnect : PlexConnect
PlexConnect : Press ENTER to shut down.
PlexConnect : ***
PlexConnect : IP_self: 192.168.1.64
PlexGDM : ***
PlexGDM : looking up Plex Media Server
PlexGDM : ***
PlexGDM : servers discovered: 1
DNSServer : ***
DNSServer : Starting up.
DNSServer : intercept trailers.apple.com: 192.168.1.64
DNSServer : forward other to higher level DNS: 192.168.1.254
DNSServer : ***
WebServer : ***
WebServer : WebServer: Serving HTTP on 0.0.0.0 port 80.
WebServer : ***
I go to Trailers on the AppleTV and it waits for a few minutes then I get an error returned. Is it something I did on the Mac Mini end or AppleTV end? Thanks for everyone's help and for putting up with questions that probably have a very simple solution.
EDIT: Also when I am connected with the Plex Connect settings on the AppleTV, I am not longer able to access Netflix, YouTube, or any of the other AppleTV apps. I can still connect to my computer and play videos from my iTunes library though. Strange?
Sounds like the DNS IP address you added to Settings.py is not correct
So should I go back to the AppleTV and reset the DNS to automatic and double check that number? It's the DNS at the bottom of the screen right?
yep, or just check it on something else on your network, whatever is easier..
