Plex Console Error
Server Version#: Version 1.8.0.1159-67c4a549
Player Version#: 1.8.0
Synology DS2513+
DSM version DSM 6.2.2-24922 Update 4
Hello
I am having a small problem with my server every few days my server stops running. I have to go in and manually tell the Plex server to run.
When I look at the console in Plex I notice this repeating error:
Error issuing curl_easy_perform(handle): 7
HTTP error requesting GET http://192.168.1.1:1990/WFADevice.xml (7, Couldn’t connect to server) (Failed to connect to 192.168.1.1 port 1990: Connection refused)
SSDP: Error parsing device schema for http://192.168.1.1:1990/WFADevice.xml
I am not sure what it means or how to fix the problem. Looking for a little advice or insight into the problem. Thanks in advance.
Jason
Please include the DEBUG log files ZIP which contains this?
Restarting PMS is the quickest way to generate all the information needed then download the log files and attach the ZIP file here.
Here are the log files
Plex Media Server Logs_2020-04-16_15-25-09.zip (3.5 MB)
My WPS is off. I turned disabled GDM. But I am still getting the errors in my console log.
