Server Version#: 1.27.2.5929
Player Version#: Version 4.84.1
Tuner Make/Model: Hauppauge WinTV-QuadHD-ATSC PCI
Guide/Lineup name: NA
Using XMLTV?: ?
Channel number/Name:
Updated Server to Debian Bullseye running Docker.
Tuner does not work after upgrade from Debian Buster.
All other settings and components are working fine but cannot record or watch OTA tv.
Dmesg shows card is recognized and firmware loaded.
Docker compose has not changed.
root:~# dmesg | grep cx23885
[ 11.177495] cx23885: cx23885 driver version 0.0.4 loaded
[ 11.178118] cx23885 0000:05:00.0: enabling device (0000 → 0002)
[ 11.178212] cx23885: CORE cx23885[0]: subsystem: 0070:6a18, board: Hauppauge WinTV-QuadHD-ATSC [card=57,autodetected]
[ 11.574547] cx23885: cx23885[0]: hauppauge eeprom: model=165100
[ 11.619513] cx25840 6-0044: cx23888 A/V decoder found @ 0x88 (cx23885[0])
[ 12.261006] cx25840 6-0044: loaded v4l-cx23885-avcore-01.fw firmware (16382 bytes)
[ 12.342910] cx23885: cx23885[0]: registered device video0 [v4l2]
[ 12.361456] cx23885: cx23885[0]: registered device vbi0
[ 12.380078] cx23885: cx23885[0]: alsa: registered ALSA audio device
[ 12.380081] cx23885: cx23885_dvb_register() allocating 1 frontend(s)
[ 12.380916] cx23885: cx23885[0]: cx23885 based dvb card
[ 12.381733] cx23885: dvb_register(): board=57 port=1
[ 12.409617] cx23885: dvb_register(): QUADHD_ATSC analog setup
[ 12.410479] dvbdev: DVB: registering new adapter (cx23885[0])
[ 12.411443] cx23885 0000:05:00.0: DVB: registering adapter 0 frontend 0 (LG Electronics LGDT3306A VSB/QAM Frontend) …
Docker Compose file…
_# required to get plex DVR working on debian buster
bootstrap:
image: busybox
user: root
command: [“chown”, “-R”, “1000:1000”, “/dev/dvb”]
networks:
- skynet
volumes:
- /dev:/dev
depends_on:
- plex-server
- handbrake
plex-server:
container_name: plex
image: plexinc/pms-docker:plexpass
environment:
- PUID=1000
- PGID=1000
- TZ=
- HOSTNAME=
- CHANGE_CONFIG_DIR_OWNERSHIP=false
- PLEX_CLAIM=
- ADVERTISE_IP=
- ALLOWED_NETWORKS=
networks:
ports:
- 32400:32400/tcp
volumes:
- /dev:/dev
- /etc/localtime:/etc/localtime:ro
- /docker/plex:/config # plex database
- /scratch/plex/transcode:/transcode # temp transcoded files
- /media/plex:/data # media library
privileged: true
restart: always
Any ideas on how to fix this?
