Plex crash when trying to open with igpu
Server Version#: 4.152.0
Intel Celeron G4930
8 gb ram
Hello guys, im running a plex server on windows 10 for the last 3-4 years without any issue. I have a plex pass and use hardware transcoding with a 1070 gpu
I wanted to see if my server could handle the transcoding only from the CPU.
When i unplugged my 1070 and remove it from the board, the computer boot and open without any issue. But the server never open. I see the logo near the clock just appear and close everytime i try to open the server manually.
When i reboot and plugged back my 1070 gpu, plex open has normal and everything works fine
Any idea what this logs error mean? Thank you very much for your help!
Oct 08, 2025 08:45:44.552 [5160] INFO - Plex Media Server v1.42.1.10060-4e8b05daf - Micro-Star International Co., Ltd. MS-7B98 x64-x64 - build: windows-x86_64 windows - GMT -04:00
Oct 08, 2025 08:45:44.553 [5160] INFO - Windows version: 10.0 (Build 19045), language fr-CA
Oct 08, 2025 08:45:44.553 [5160] INFO - 2 3192 MHz processor(s): Architecture=9, Level=6, Revision=40459 Processor Identifier=Intel64 Family 6 Model 158 Stepping 11, GenuineIntel
Oct 08, 2025 08:45:44.553 [5160] INFO - Compiler is - MSVC 1929
Oct 08, 2025 08:45:44.553 [5160] DEBUG - “C:\Program Files\Plex\Plex Media Server\Plex Media Server.exe”
Oct 08, 2025 08:45:44.484 [3900] DEBUG - Plex for Windows Store application is not installed
Oct 08, 2025 08:45:44.485 [3900] DEBUG - BPQ: [Idle] → [Starting]
Oct 08, 2025 08:45:44.490 [3900] DEBUG - FeatureManager: Using cached data for features list
Oct 08, 2025 08:45:44.493 [3900] DEBUG - MyPlex: mapping state set to ‘Unknown’.
Oct 08, 2025 08:45:44.493 [3900] DEBUG - Relay: read 26 cached entries from hosts file
Oct 08, 2025 08:45:44.519 [3900] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.39.4, threadsafe=1
Oct 08, 2025 08:45:44.531 [3900] INFO - SQLITE3:0x2, 283, recovered 123 frames from WAL file C:\Users\Plex\AppData\Local\Plex Media Server\Plug-in Support\Databases\com.plexapp.plugins.library.db-wal
Oct 08, 2025 08:45:44.597 [3900] DEBUG - MyPlex: using cached data for request for https://plex.tv/api/v2/server/users/features
Oct 08, 2025 08:45:45.031 [3900] DEBUG - [CERT] Subject name is /CN=*.b9baad76500d4614b2e8e2364863aef2.plex.direct
Oct 08, 2025 08:45:45.032 [3900] DEBUG - [CERT] Installed certificate with fingerprint d1:de:20:37:22:5e:5f:2b:3c:5b:87:a6:b2:54:d0:d8:a6:dc:a3:c7.
Oct 08, 2025 08:45:45.032 [3900] DEBUG - [CERT/OCSP] no URL available
Oct 08, 2025 08:45:45.032 [3900] WARN - [CERT/OCSP] getCertInfo failed; skipping stapling
Oct 08, 2025 08:45:45.032 [3900] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
Oct 08, 2025 08:45:45.032 [3900] DEBUG - HttpServer: Listening on port 32400.
Oct 08, 2025 08:45:45.034 [3900] DEBUG - HttpServer: Listening on port 32401.
Oct 08, 2025 08:45:45.034 [3900] DEBUG - Running server…
Oct 08, 2025 08:45:45.034 [3900] INFO - Running migrations. (EPG 0)
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 0.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 1.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 2.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 3.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 4.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 5.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 6.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 7.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 8.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 9.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 10.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 11.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 12.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 13.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 14.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 15.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 16.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 17.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 18.
Oct 08, 2025 08:45:45.035 [3900] DEBUG - Captured session 19.
Oct 08, 2025 08:45:45.059 [9060] DEBUG - HttpServer: Set up a thread pool with 2 threads.
Oct 08, 2025 08:45:45.114 [3900] DEBUG - ChangestampAllocator: initialized to 7686990
Oct 08, 2025 08:45:45.152 [3900] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.39.4, threadsafe=1
Oct 08, 2025 08:45:45.179 [3900] INFO - SQLITE3:0x2, 283, recovered 732 frames from WAL file C:\Users\Plex\AppData\Local\Plex Media Server\Plug-in Support\Databases\com.plexapp.plugins.library.blobs.db-wal
Oct 08, 2025 08:45:45.185 [3900] INFO - Running migrations. (EPG 0)
Oct 08, 2025 08:45:45.185 [3900] DEBUG - Captured session 0.
Oct 08, 2025 08:45:45.185 [3900] DEBUG - Captured session 1.
Oct 08, 2025 08:45:45.235 [2840] DEBUG - [GPU] Got device: Intel(R) UHD Graphics 610, intel@unknown, default true, best true, ID 8086:3e93:1462:7b98, DevID [8086:3e93:1462:7b98], flags 0x38f6
Oct 08, 2025 08:45:47.402 [12948] ERROR - Thread: Couldn’t add a new thread to the pool of size 1: resource unavailable try again: resource unavailable try again
