Server Version#: 1.13.8.5395
My server has crashed SEVERAL times during the week. And it’s starting to annoy me. here is what it’s in the log:
Oct 14, 2018 19:22:31.495 [8792] DEBUG - TrayIcon::WindowProc received DisplayIcon timer message
Oct 14, 2018 19:22:31.495 [8792] WARN - Shell_NotifyIcon(NIM_ADD) failed: 0x0
Oct 14, 2018 19:22:36.511 [8792] DEBUG - TrayIcon::WindowProc received DisplayIcon timer message
Oct 14, 2018 19:22:36.511 [8792] WARN - Shell_NotifyIcon(NIM_ADD) failed: 0x0
Oct 14, 2018 19:22:41.511 [8792] DEBUG - TrayIcon::WindowProc received DisplayIcon timer message
Oct 14, 2018 19:22:41.511 [8792] WARN - Shell_NotifyIcon(NIM_ADD) failed: 0x0
Oct 14, 2018 19:22:46.526 [8792] DEBUG - TrayIcon::WindowProc received DisplayIcon timer message
Oct 14, 2018 19:22:46.526 [8792] WARN - Shell_NotifyIcon(NIM_ADD) failed: 0x0
Oct 14, 2018 19:22:51.542 [8792] DEBUG - TrayIcon::WindowProc received DisplayIcon timer message
Oct 14, 2018 19:22:51.542 [8792] WARN - Shell_NotifyIcon(NIM_ADD) failed: 0x0
Oct 14, 2018 19:22:56.542 [8792] DEBUG - TrayIcon::WindowProc received DisplayIcon timer message
Oct 14, 2018 19:22:56.542 [8792] WARN - Shell_NotifyIcon(NIM_ADD) failed: 0x0
Oct 14, 2018 19:23:01.542 [8792] DEBUG - TrayIcon::WindowProc received DisplayIcon timer message
Oct 14, 2018 19:23:01.542 [8792] WARN - Shell_NotifyIcon(NIM_ADD) failed: 0x0
Oct 14, 2018 19:23:06.542 [8792] DEBUG - TrayIcon::WindowProc received DisplayIcon timer message
That just lists over and over again. It seems users Authenticate between those lines, then those lines just repeat, until a restart is done on the PMS server.
I have it running as a service. Anything else you need, as i have an hour worth of bad stuff in the log on when it was “crashed”.
