Plex CRITICAL (runtime: 1128)
Hi everybody
I was watching a movie on Plex today, casting from my android phone to chromecast. Suddenly after around 30 min the movie turned of and grey screen appered with an error saying something like “h4 not supported”, this happened every 30 minutes or so, the rest of the movie. I then check the log and found this error around the time of the crash:
2025-04-16 21:38:56,207 (7fb58b2bfb38) : CRITICAL (runtime:1128) - Exception in thread named ‘refresh_servers’ (most recent call last):
File “/usr/lib/plexmediaserver/Resources/Plug-ins-d301f511a/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/runtime.py”, line 1126, in _start_thread
f(*args, **kwargs)
File “/usr/lib/plexmediaserver/Resources/Plug-ins-d301f511a/System.bundle/Contents/Code/peerservice.py”, line 169, in refresh_servers
servers_el = self.get_servers_el()
File “/usr/lib/plexmediaserver/Resources/Plug-ins-d301f511a/System.bundle/Contents/Code/peerservice.py”, line 165, in get_servers_el
return XML.ElementFromURL(‘http://“my IP-address”/servers’, cacheTime = 0)
File “/usr/lib/plexmediaserver/Resources/Plug-ins-d301f511a/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/parsekit.py”, line 344, in ElementFromURL
method=method,
File “/usr/lib/plexmediaserver/Resources/Plug-ins-d301f511a/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/networkkit.py”, line 67, in _http_request
req = self._core.networking.http_request(url, *args, **kwargs)
File “/usr/lib/plexmediaserver/Resources/Plug-ins-d301f511a/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py”, line 352, in http_request
return HTTPRequest(self._core, url, data, h, url_cache, encoding, errors, timeout, immediate, sleep, opener, follow_redirects, method)
File “/usr/lib/plexmediaserver/Resources/Plug-ins-d301f511a/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py”, line 119, in init
self.load()
File “/usr/lib/plexmediaserver/Resources/Plug-ins-d301f511a/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py”, line 159, in load
f = self._opener.open(req, timeout=self._timeout)
File “/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py”, line 435, in open
response = meth(req, response)
File “/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py”, line 548, in http_response
‘http’, request, response, code, msg, hdrs)
File “/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py”, line 473, in error
return self._call_chain(*args)
File “/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py”, line 407, in _call_chain
result = func(*args)
File “/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py”, line 556, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 503: Service Unavailable
Does anyone know how to fix this?
I recently installed a GTX 1660 and there has been a few problems with transcoding in Plex since then.
