Plex Database issues - what are my options?
Server Version#: plexpass-1.32.3.7192
Jun 16, 2023 07:34:50.793 [0x8065ae000] INFO - Vacuuming database.
Jun 16, 2023 07:34:54.788 [0x8065ae000] ERROR - SQLITE3:0x10, 13, statement aborts at 8: [INSERT INTO vacuum_db.'media_streams' SELECT*FROM"main".'media_streams'] database or disk is full
Jun 16, 2023 07:34:54.797 [0x8065ae000] ERROR - SQLITE3:0x10, 13, statement aborts at 1: [VACUUM] database or disk is full
Jun 16, 2023 07:34:54.804 [0x8065ae000] ERROR - Exception thrown during migrations, aborting: sqlite3_statement_backend::loadOne: database or disk is full
Jun 16, 2023 07:34:55.202 [0x8065ae000] DEBUG - ChangestampAllocator: initialized to 87663346
Jun 16, 2023 07:34:55.259 [0x8065ae000] DEBUG - Opening 2 database sessions to library
Jun 16, 2023 07:34:55.260 [0x8065ae000] INFO - SQLITE3:0x10, 283, recovered 137 frames from(com.plexapp.plugins.library.blobs), SQLite 3.39.4, threadsafe=1 WAL file /mnt/pool/jail/plexpass/plexdata/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db-wal
Jun 16, 2023 07:34:55.265 [0x8065ae000] INFO - Running migrations. (EPG 0)
Jun 16, 2023 07:34:55.265 [0x8065ae000] DEBUG - Captured session 0.
Jun 16, 2023 07:34:55.265 [0x8065ae000] DEBUG - Captured session 1.
Jun 16, 2023 07:34:55.265 [0x8065ae000] INFO - Analyzing database.
Jun 16, 2023 07:34:55.321 [0x8065ae000] INFO - Vacuuming database.
Jun 16, 2023 07:34:57.509 [0x8065ae000] ERROR - SQLITE3:0x10, 13, statement aborts at 7: [INSERT INTO vacuum_db.'blobs' SELECT*FROM"main".'blobs'] database or disk is full
Jun 16, 2023 07:34:57.518 [0x8065ae000] ERROR - SQLITE3:0x10, 13, statement aborts at 1: [VACUUM] database or disk is full
Jun 16, 2023 07:34:57.520 [0x8065ae000] ERROR - Exception thrown during migrations, aborting: sqlite3_statement_backend::loadOne: database or disk is full
Jun 16, 2023 07:34:57.521 [0x808c8d000] DEBUG - Codecs: Downloading current version of vc1 decoder
Jun 16, 2023 07:34:57.521 [0x808c8d000] INFO - CodecManager: obtaining decoder 'vc1'
Jun 16, 2023 07:34:57.522 [0x808c8d000] DEBUG - [HCl#1] HTTP requesting GET https://plex.tv/api/codecs/vc1_decoder?build=freebsd-x86_64-standard&deviceId=versionstuff
Jun 16, 2023 07:34:57.533 [0x808c8d000] DEBUG - Grabber: Cleaning up orphaned grabs.
Jun 16, 2023 07:34:57.533 [0x8065ae000] DEBUG - Media Provider: Registering provider com.plexapp.plugins.library
Jun 16, 2023 07:34:57.533 [0x8065ae000] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
Jun 16, 2023 07:34:57.533 [0x808c57000] DEBUG - [MediaProviderManager/HCl#2] HTTP requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jun 16, 2023 07:34:57.533 [0x8065ae000] DEBUG - MyPlex: using cached data for request for https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx
Jun 16, 2023 07:34:57.534 [0x8065ae000] DEBUG - MyPlex: updating with 28 access tokens
Jun 16, 2023 07:34:57.534 [0x808c8d000] DEBUG - Grabber: Cleaned up 0 decrepit directories in 0.0 sec.
Jun 16, 2023 07:34:57.538 [0x8065ae000] DEBUG - MyPlex: using cached data for request for https://plex.tv/api/v2/server/users?auth_token=xxxxxxxxxxxxxxxxxxxx
Jun 16, 2023 07:34:57.538 [0x8065ae000] DEBUG - MyPlex: using cached data for request for https://plex.tv/api/v2/server/users/subscriptions?auth_token=xxxxxxxxxxxxxxxxxxxx
Jun 16, 2023 07:34:57.538 [0x8065ae000] DEBUG - MyPlex: using cached data for request for https://plex.tv/api/v2/server/users/services?auth_token=xxxxxxxxxxxxxxxxxxxx
Jun 16, 2023 07:34:57.539 [0x808c04500] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
Jun 16, 2023 07:34:57.539 [0x808c04500] DEBUG - [HCl#3] HTTP requesting GET https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx
Jun 16, 2023 07:34:57.539 [0x8065ae000] ERROR - SQLITE3:0x10, 1, no such table: metadata_agent_providers in "update metadata_agent_providers set online = 0"
Jun 16, 2023 07:34:57.539 [0x8065ae000] ERROR - Error: Unable to set up server: sqlite3_statement_backend::prepare: no such table: metadata_agent_providers for SQL: update metadata_agent_providers set online = 0 (N4soci10soci_errorE)
So I had a disk full error, cleaned up my server and have space. Loaded a backup db, upgraded plexpass and this is all I get. Am I doomed?
DB file size is roughly 670MB. I have tried a recovery which failed as well.
How can I salvage this…
